I wanted to alert you guys that when you winterize the antifreeze might set of your CO2 alarm.
We never had it happen before but we sure did yesterday.  I reset it a bunch of times and kept scratching my head.  Cindy found something via the Google about it. The antifreeze has alcohol in it and can set off the alarm.
I just found these other little tidbits about RV Antifreeze -
  • Drying Rubber Seals: Repeated long-term exposure to high-concentration ethanol can dry out or degrade rubber O-rings, pump diaphragms, and toilet blade seals over time.
  • Taste & Odor: Ethanol leaves a distinct alcohol smell and can impart a persistent chemical taste to PEX lines and vinyl hoses that takes extensive flushing to remove in the spring.
  • Flammability: Because of the grain alcohol content, some low-cost ethanol-blend antifreezes are potentially flammable in concentrated liquid or vapor forms when exposed to an open flame.
Super Tech RV & Marine Antifreeze Odorless Formula 1 Gallon
I aired out the Ollie overnight and the alarm is off and that pretty little green light is bright and shiny.
Great post and thank you Cindy!  Below is a long version with a couple of alternate RV products than the Super Walment Center Super Tech version that many of us have been using.
Owners:
  • If there are other less expensive sources please advise all.
  • Have we seen any long term damage in our OTT's?  (I have used it for 9 winters and have not experiencned any).  If none by others then maybe the topic is over-blown.
RV ANTIFREEZE (Keep).docx
