Hikegsm Posted May 7, 2017 Posted May 7, 2017 I didn't want to struggle moving the mattress every time we needed to turn the water/pump valves for filling our water tank while boondocking so I asked Oliver to install an access door. It required them to move a duct for the furnace but they did it. In my opinion it should be a standard option but is not listed in the build sheets. It works great I highly recommend getting it. We also had an acesss door placed under the nightstand for easier access to the far end of the basement storage. I think it will be handy. 5 Yvonne & Doug 2017 Legacy Elite II, twin bed Hull #223 2017 Ford F-250 Lariat, crew cab
Hikegsm Posted May 7, 2017 Author Posted May 7, 2017 Pictures of nightstand access 3 Yvonne & Doug 2017 Legacy Elite II, twin bed Hull #223 2017 Ford F-250 Lariat, crew cab
Overland Posted May 8, 2017 Posted May 8, 2017 Thanks for the photos. I'm curious why both the access port and door on the curb side. Could the door not be positioned so that you have access to everything you need without having the added port?
Hikegsm Posted May 8, 2017 Author Posted May 8, 2017 Good question. I am not sure why they have that access port. I was told by Anita that it was not large enough of an opening to reach all the valves. I sure don't think I could reach them without the door. I suppose the port was already in when I asked for the door. Yvonne & Doug 2017 Legacy Elite II, twin bed Hull #223 2017 Ford F-250 Lariat, crew cab
Try2Relax Posted May 8, 2017 Posted May 8, 2017 They started incorporating the access hatch when more people asked about it to reach just the gravity drain valve easily for breakdown, so I believe it is now standard, asking for anything else just gets you more in addition. 2 Randy One Life Live It Enjoyably 2017 F350 6.7L SRW CC LB 2015 Oliver Elite II Hull #69
KarenLukens Posted May 12, 2017 Posted May 12, 2017 The access port also allows easy access to the Suburban heater's reset switch located on the right side of the heater... 1 Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II
Bruce W Posted May 13, 2017 Posted May 13, 2017 You are showing an access door on the curb side and one under the night stand. Is one of these now a standard? Does it cost much to add them? Do you use them? Bruce & Vas
Hikegsm Posted May 13, 2017 Author Posted May 13, 2017 You are showing an access door on the curb side and one under the night stand. Is one of these now a standard? Does it cost much to add them? Do you use them? The doors are not standard. The round access port is standard. I use the doors to for easy access to the the water pump valves (curbside) and the rear of the basement storage compartment ( nightstand door). The were $175 each. 1 Yvonne & Doug 2017 Legacy Elite II, twin bed Hull #223 2017 Ford F-250 Lariat, crew cab
KarenLukens Posted May 14, 2017 Posted May 14, 2017 Going back to the title, we would have liked another AC outlet on either the front or preferably the right side of the stove. Then another on the street side towards the front from the storage compartment because most of the outside work goes on right there. We turned the fold down door into a level light weight work table. The pantry is the only cabinet without a light and it could really use one :) 2 Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II
