Landrover Posted May 15, 2019 Posted May 15, 2019 Question. I never had a extra 30 amp outlet for a generator on any trailer I’ve had. Are both 30amp receptacles tied into the main panel? Does the 30 amp generator receptacle have a cut off switch. If they are both connected to the main panel with no cut off switch. When you ran a generator would that back feed to the shore 30amp receptacle making that live. And visa versa. Hope i asked this in the simplest way possible. Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
Moderator+ ScubaRx Posted May 15, 2019 Moderator+ Posted May 15, 2019 If your trailer is equipped with both receptacles, then there should be a transfer switch wired between them to prevent the scenario you’ve described. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Landrover Posted May 16, 2019 Author Posted May 16, 2019 Thanks ScubaRx I didn’t see any diagram that showed this. I would think the 2019 elite II would have this in the system. one more question to ask at the Delivery. Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
