Not in any way will it replace a Viair. They do not list the flow rate (cfm) but it can only run for 5 minutes then rest 5.... which is VERY feeble performance. Good enough to top up a small bike tire, or maybe a car tire by a few psi. Not good enough to pump up a nearly flat Ollie or truck tire, for that you need at least 2 cfm, unless you are prepared to wait a long time. You certainly could not blow out any water lines, or remove dust.
If somebody can find the flow rate, please comment. I find it to be a little odd that it is not listed, even in the operating manual.....
If you want a pretty decent pump with a very high flow rate and not pay for a larger Viair, consider this one.
https://www.amazon.com/Smittybilt-2781-5-65-Universal-Compressor/dp/B004K25GMG
https://www.fourwheeler.com/product-reviews/1306-4wd-smittybilt-2781-air-compressor/
Great feedback and suggestion. Thanks
2020 Ram 1500 Ecodiesel. LE2 hull# 344 with Grace and Maya Papaya - our 2 golden retrievers.
