Storage Bin for Elite II Basement - What is the largest known brand and size currently known to fit?
I did some digging for a few hours and gave up. Web filters for storage bin sizes seem to fail on almost every online retailer I've tried. I'm looking to fill the area directly behind the outdoor access panel.
Edited by Jairon
2019 Toyota Land Cruiser
Where I'm at after more research:
IRIS container confirmed to fit from thread:
Size:
W:15 11/16"
L: 21 5/8"
H: 10 11/16"
Possible larger alternative that should fit: https://www.irisusainc.com/weathertight-storage-box-46-6-qt-ucb-sd
Might be possible with or without the lid. I'm unsure what the actual height is in the basement: https://www.irisusainc.com/sliding-storage-box-61-qt-ssb-60-green
I'm going to keep searching but hopefully this will help someone.
Edited by Jairon
I posted about the 15 11/16 wide x 21 5/8 long x 10 11/16 high storage box in the earlier thread you noted.
The 19.70 x 15.75 x 11.75 storage box you linked to should fit fine.
I think the 23.4 x 15.6 x 13.0 Inches storage box would be problematic, as I think the 23.4 inch dimension is too long to fit. I think the dimension is 22 inches until you reach the edge of the twin bed.
You probably could rotate it as you put through the door, but then the 15.6 inch dimension would be wasting storage space (22-15.6 inches).
Thanks for that very useful post, David. I was hopeful for the 23.4 inch long version based on CedarForks' custom tub design:
I was hopeful that with 3.1 inches lopped off the end, it would fit. Rounded corners are tricky though and I have no idea how accurate his drawing is 🤪 Based on Oliver's basement video, the shape looks very different:
Edited by Jairon
