I stumbled upon this site selling Dinosaur boards.  It may or may not be the one you need, but the description says it is a replacement for the 293 series boards.  I haven’t had any problems with my refrigerator to date, so I don’t have any practical knowledge concerning troubleshooting your problem.
  • 2 years later...
Hello kids.  Over the past 3 years my Dometic RM 2454 eyebrow board was responding to a few tricks to get the fridge started; see previous posts in this thread.  First, hold the "On" switch in for a few seconds.  When that gave no joy, pull the panel out and unplug, then replug the connector.  Finally, pull the panel out and shim the connector with a strip of paper towel.
Once it started it never crapped out.
Yesterday, it refused to respond to any of these.  BUT.......
I found the eyebrow and power boards are now manufactured at Dinosaur Electronics.
Here is a link from a vendor that carries them, for the eyebrow board.  You can find the replacement power board (Black Box outside) on the site easily.
https://www.rvshop.com/Eyebrow-Board-Replacement-2-WAY-3-WAY-Dinosaur-Electronics-DE-ADJ_p_79109.html
The Black Box Dometic boards should have the part number on the front of the box, in the smallest imagineable font.  Mine is part number 385071201, and RVSHOP carries a Dinosaur board to replace it.  The eyebrow board will supposedly will work with the OEM power board.  I will order both in a few weeks and re-post.  Just spent $4000 on my Jeep and F-250, tight right now.
Jim
PS:  I am quite happy with my Oliver, but I will NEVER buy another RV without ordering a full set of boards that are proven to work.  This will be a non-negotiable.  This way, companies like Dometic can't stick you with garbage that breaks, with no repair parts available, so then it's "Whoopsie Poopsie, $2500 for a new fridge install!"
Edited by Jim Harper
  • 5 months later...
Have installed Dinosaur board, works fine for a while on gas then for some reason it stops, switches to electric.  Probably overheating.  I'm in Florida, thie trailer is on the West side of the house next to a fence on a rock hardscape.
Fridge stays cold.  More to come.
I can live with it for now.
@Jim Harper, if you switch from auto to gas, does it just stop? May be a fuel line problem (air bubble?)
Try burning off fuel by using the cooktop a bit, and see if the problem resolves. At least, that's what I did with our old 3 way, to troubleshoot.
