7 minutes ago, Mike D. said:
My 2021, #797 had a BlueSeas disconnect installed as standard.
As it should be.  Is the cutoff on the input or output of the charge controller?
It is installed on the positive wire between the panels and the input of the controller.
Thank you.  That makes sense to me based on the location.
