The thermostat can be placed on low, high and auto but the low speed will never work.  It always blows high.  Is this a normal quirk with our Ollies?
LE II  Hull #1049
2022 Tundra Limited 4X4
No, not normal.  We run our AC on low almost all the time.  There is a noticeable difference between low and high, I wish there was more because low is still pretty loud.  Mike
Thanks for the speedy reply.  I would be very happy with a low speed at this point.  No difference in blower speed if thermostat shows High or Low.  Auto works but always on high speed.  I guess I will put in a service ticket unless there is some reset possible on thermostat.
LE II  Hull #1049
That thermostat has some tricks.
Do a search. I'll see if i can find something for you.
Most reported problems are furnace running.
