Sounds like it may be the bolts that hold the propane shroud on. This thread may have some information for you.
Jerry & Kathy
7 hours ago, Coach and JoJo said:
Mike at Oliver gave me some easy instructions on how to access the bolts...Easy fix!!!
That's good news! When you have done the work can you please share your experience, perhaps with photos?
Locate the  small wash rag hangers under the sink.
You will see 4 white screw covers....pop off with a flat head screw driver.
This reveals 4 screws to remove.
Remove the hanging rack from the hole, be careful of the switch at the top.
You can then locate the two bolts.
I tighted back up with a rachet lock nut and lock washer...I actally put on another lock washer and a nut for redundancy. Then put duct tape over the last 3/4 inch of the exposed threads.   (In the South it Ain't fixed to you apply the duct tape)
