Mountainman198 Posted August 29, 2022 Share Posted August 29, 2022 Has anyone used any of Seasucker's items on their Ollie or on a fiberglass boat? I am intrigued by several of their items and was hoping for a Ollie testimonial before pulling the trigger. https://www.seasucker.com Their lineup appears appealing as it includes everything from paper towel holders, safety handles, solar mounts, bike rack and bare suction mounts which can be customized to whatever utility is desired. Very pricey but I am intrigued. 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW Link to comment Share on other sites More sharing options...
Guest Posted August 29, 2022 Share Posted August 29, 2022 Hello, Not a lot of room on the Oliver, especially if you have solar panels. I'm not sure they would fit anywhere. Did you have an idea about a mounting location? Kirk Link to comment Share on other sites More sharing options...
Mountainman198 Posted August 29, 2022 Author Share Posted August 29, 2022 19 minutes ago, Kirk Peterson said: Hello, Not a lot of room on the Oliver, especially if you have solar panels. I'm not sure they would fit anywhere. Did you have an idea about a mounting location? Kirk I might get two of these and make a table that would attach to the side of the Ollie, using a telescoping leg to support the outer edge. I camp in a lot of windy places and have yet to find. table that doesn't need to be taken down each night and put away so it doesn't blow over. I might even get a third to mount a wireless backup camera. https://www.seasucker.com/collections/marine/products/4-1-2-seasucker-black The bike racks are interesting but I am not sure I am ready to trust suction cups to hold bikes to the rear of a travel trailer. Same with the solar panel mounts, however if I didn't already have solar the suction mounts might be cool to use for a panel or two when in camp and not wanting to place the panels on the ground. 2 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW Link to comment Share on other sites More sharing options...
Guest Posted August 29, 2022 Share Posted August 29, 2022 1 hour ago, Mountainman198 said: I might get two of these and make a table that would attach to the side of the Ollie, using a telescoping leg to support the outer edge. Cool idea! 👍 Link to comment Share on other sites More sharing options...
Dave Mazone Posted August 30, 2022 Share Posted August 30, 2022 12 hours ago, Mountainman198 said: Has anyone used any of Seasucker's items on their Ollie or on a fiberglass boat? I am intrigued by several of their items and was hoping for a Ollie testimonial before pulling the trigger. https://www.seasucker.com Their lineup appears appealing as it includes everything from paper towel holders, safety handles, solar mounts, bike rack and bare suction mounts which can be customized to whatever utility is desired. Very pricey but I am intrigued. I use a couple of them. One for paper towels and the other for my waste bag. They hold for a day or two, then a couple pumps on the push rod to tighten them up (the pushrod shows when the suction is waning). They're neat, clean and good looking on the white interior. And, you can move them easily! 1 1 Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD) Link to comment Share on other sites More sharing options...
