That's a bummer.
I broke my freezer door, different brand, though. I had to order a new door.
I'd open a service ticket and see if you are covered under warranty.
Our freezer door hinge also broke very recently-a very small plastic part broke off. Ordered a spring holder part from Amazon, it just arrived so it hasn't been installed yet.  Probably should have made a ticket as the small part was about $25. Hopefully this is the correct part
6 hours ago, SeaDawg said:
That's a bummer.
Ticket opened, thanks.  Will probably seek out a service center around Ft Davis, TX.  We'll be there for a rall
Hi Kathy,
That is the correct part for the left side.  The right is 919041.  If you have two hex head screws underneath the freezer door, Norcold told me to simply remove the screws on one side and wiggle the assyembly out.  After the reassembly you gently push it back up to where the tabs pop back into its hole.  Norcold is going to send me the parts to Ft Davis park in Texas and I've notified the campground its coming so hopefully I'll get it fixed... we have 2 weeks at the park and it sems pretty simple.  Norcold doesn't normally send parts to the end user but in this case (being simple) they will and it's covered by warranty.  However if I mess something up as far as functioning of the fridge, I'll void all warranty.
Best of luck,
Update: the part was installed today and was the correct part
Just now, Kathy Tewart said:
Update: the part was installed today and was the correct part, I should have mentioned this is for a Norcold fridge, 2022 Ollie
