Outdoor Shower-Antifreeze Not Flowing - Help!
Try the cold water side first and if that works then do the hot water side.
I assume that you turned the water heater bypass on.
Forgive me if this is a stupid question: Did you open the lever valve on the shower head?
Did you say the pump is running even with nothing flowing? The pump should shut off if there's no flow anywhere in the trailer.
One more thing you might try is to unscrew the head on the shower head.  Sometimes that can get clogged.
This is why I asked if they had used the water heater bypass.
