How to Keep Your Pets Safe on RV or Trailer Trips
JWalmsley
  • Administrators
Share and Enjoy !
Shares
Are you planning an RV or travel trailer trip with your pets this summer? If so, it's important to make sure that they are safe and comfortable while on the road. There are a number of things you can do to keep them safe and happy, including following these tips from Oliver Travel Trailers. Whether you're a seasoned traveler or just hitting the open road for the first time, it's important to plan ahead for your furry friends. Pets can be unpredictable and may run off if they get spooked, so it's crucial to take some precautions before you set out on your journey. Here are our top tips for keeping your pets safe on RV or travel trailer trips.
Before you even hit the road, make sure your pet is microchipped and up to date on all their vaccinations. This will help ensure that they can be properly identified if they do happen to run off while you're on your trip. This will ensure that you're reunited as soon as possible.
Ensure that your pet has a collar or harness with ID tags.  This is one of the most important tips for keeping your pets safe on your trips. Always make sure that your pets are wearing a collar or harness with ID tags that include your name, address, and phone number. This will help ensure that they can be returned to you if they do get lost.
Securing your pet while the RV or travel trailer is moving.  If you're traveling with pets, it's important to make sure that they are secured while the trailer is in motion. Pets can get scared and run off if they're not properly restrained, so it's important to use a pet carrier or harness. For smaller pets, you can purchase a pet seatbelt or other type of restraint that will keep them securely in their seat. If you have a larger pet, consider investing in a pet gate to keep them contained in one area of the RV or travel trailer. Never leave your pet unattended. It's important to never leave your pet unattended, especially in hot weather. Pets can overheat quickly, so it's crucial to make sure that they always have access to shade and water.
Once you're on the road, it's important to keep an eye on your pets at all times, especially when they're near busy roads or areas with a lot of foot traffic. If possible, keep them on a leash or in a carrier when you're not able to watch them closely. And always make sure they have access to fresh water and shade when it's hot outside.
Create a pet-friendly space in your trailer.  One of the best ways to keep your pets safe on your trailer trips is to create a pet-friendly space in your rig. This means having plenty of food and water bowls, as well as a comfortable place for them to sleep. You may also want to bring along some of their favorite toys to keep them entertained. If you have a cat, be sure to bring along a litter box.
Now, what about sightseeing you without your furry friend or pet? You will want to go places that may not allow pets, and you will need to leave them with the camper while you go off and explore.
First, do some research before you go.  Not all RV parks and campgrounds are pet-friendly, so it's important to do your research before you go. Look for parks that have designated areas for pets, as well as plenty of space for them to run and play. Be sure to read the rules and regulations of each park before you make a reservation, as some may have restrictions on the type or number of pets allowed.
If you need to leave your site without your pet, make sure that you're in an area that will have shade so they don't get too hot. Make sure your RV or travel trailer can have running AC if you're leaving them in the trailer while you're gone, and always leave fresh water and food out for them.
To quote KOA.com. "As you travel, you are bound to want to try out a restaurant or tour a museum that doesn’t allow pets. There are many ways to make sure your pet stays comfortable and safe if you need to leave them in your trailer. Just like a regular car, you can’t close up your pet inside the RV or trailer and go about your day unless you are sure they can stay cool. If it is 80 degrees outside, temperatures in a closed car can climb to 114 degrees in just 30 minutes."
You may want to take advantage of any window blinds or shades inside your trailer that can protect the interior from UV rays and keep your pet at a better temperature. Depending on your animal, they may need more air or need to be cooler than others. Take all of that into consideration before you take your animal with you. You also can equip your RV or trailer with a remote thermostat so you can control it from afar and adding a pet camera inside your travel trailer will also help give you peace of mind. A doggie water fountain will help keep pets hydrated. Make sure your trailer is pet-proofed before you leave. Pets can be curious creatures, and it's important to make sure that all poisonous plants and dangerous chemicals are out of reach. Store them in high cabinets or on shelves that your pets can't reach.
As much as we love our pets, there are some places they just aren't welcome. When planning your RV or trailer trip, be sure to research pet-friendly parks and campgrounds in advance so you can find the perfect spot for you and your furry friend. And always take precautions to keep your pet safe and comfortable while on the road. With a little planning, you can enjoy a stress-free RV trip with your pet!
Finally, never leave your pet alone in a parked car. This is one of the most important tips for keeping your pets safe on trailer trips. Pets can overheat quickly in a parked car, even if the windows are cracked open. If you're going to be gone for more than a few minutes, it's best to leave your pet at home or in the care of someone else.
By following these simple tips, you can help ensure that your pets have a safe and enjoyable RV trip. Do you have any other tips for keeping pets safe on the road? Share them with us in the comments below!
Pets are a great addition to any trailer trip. Following these simple tips will help ensure that your pets are safe and happy during your RV travels this summer.
Share and Enjoy !
Shares
The post How to Keep Your Pets Safe on RV or Trailer Trips appeared first on Oliver Travel Trailers.
Read the Full Article
Full Stack Developer/Marketing @ Oliver Companies
Oliver Forums Guidelines & Rules
