  • Administrators
Share and Enjoy !
Shares
If you've ever found yourself with low water pressure in your RV, you know it can be a real pain. Not being able to take a proper shower or do the dishes can put a serious damper on your camping trip. Luckily, there are some things you can do to help improve the water pressure in your RV. Here are 8 tips for dealing with water pressure in your travel trailer or RV.
Check for leaks
One of the first things you should do if you're having low water pressure in your RV is to check for leaks. Even a small leak can cause big problems when it comes to water pressure. You'll want to check all of the hoses and fittings in your RV for any signs of leaks. If you find a leak, be sure to turn off the active water source and find ways to fix or replace the damaged part.
Use a water pressure regulator
If your RV is hooked up to a city water supply, it's a good idea to use a water pressure regulator. This will help keep the water pressure in your RV at a consistent level, which can prevent problems like low water pressure. You can typically find water pressure regulators at most hardware stores.
Invest in a water pump
If you frequently camp in areas with limited water resources, it might be a good idea to invest in a water pump. A water pump can help increase the water pressure in your RV, making it easier to take showers and do dishes. Water pumps are relatively affordable and can be found at most RV Supply shops or even local retailers.
Don't use too many fixtures at once
Don't use too many fixtures at once. If you're trying to take a shower and do the dishes at the same time, you're likely to experience low water pressure. This is because the water has to travel through more fixtures, which can reduce the pressure. Try to limit yourself to using one fixture at a time if possible. You can also take shorter showers. If you're used to taking long showers, you might need to adjust your habits when RVing. Low water pressure can make it difficult to get all the soap off your body, so it's best to take shorter showers. This will help conserve water and prevent low water pressure issues.
Clean your water filter
If you have a water filter in your RV, it's important to clean it on a regular basis. A dirty water filter can cause low water pressure, as well as other problems. You should consult your RV's owner's manual to find out how often to clean your water filter. If you have low water pressure in your RV, one of the first things you should check is your water filter. A clogged water filter can severely restrict the flow of water, resulting in low water pressure. To clean your RV water filter, simply remove it and rinse it off with a garden hose. If the filter is really dirty, you may need to soak it in a bucket of soapy water for a few hours before rinsing it off. Once your RV water filter is clean, reattach it and turn on the water to see if the pressure has increased.
Check the water heater bypass valve
If your RV has a water heater bypass valve, make sure it's in the proper position. The bypass valve allows water to bypass the water heater, which can help increase water pressure. Consult your RV's owner's manual to find out where the bypass valve is located and how to properly adjust it. This valve is responsible for regulating the amount of water that goes through the heater. If it is set too low, it can restrict the flow of water and cause low water pressure. You can adjust this valve by turning it clockwise or counterclockwise. Another thing that you can do is bleed the air out of the lines. This can be done by opening the faucets and letting the water run for a few minutes. This will help to get rid of any air that is trapped in the lines.
Winterize your RV
If your RV is going to be sitting for a while, it's important to winterize it. This will help prevent low water pressure and other problems. To winterize your RV, simply turn off the water supply and open all the faucets in your RV. This will allow any remaining water to drain out of the lines. Once the water has drained out, add some RV antifreeze to the lines. This will help prevent the water from freezing and causing damage. Finally, close all the faucets and turn off the power to your RV. This will help conserve energy and prevent any unnecessary damage.
Get professional help
If you're having trouble troubleshooting low water pressure in your RV, it's best to get professional help. There are a number of RV dealers and service centers that can help you diagnose and fix the problem. They will likely be able to offer more tips and advice than what is available online or in manuals. In addition, they will have the proper tools and equipment to properly fix the problem. Getting professional help is always the best course of action when dealing with complex issues like low water pressure.
So to wrap up: If your RV is having low water pressure issues, there are a number of things you can do to try to fix the problem. First, check your water filter and make sure it's clean. If it's dirty, clean it off with a garden hose. Next, check the water heater bypass valve and make sure it's in the proper position. You can also try bleeding the air out of the lines by opening the faucets and letting the water run for a few minutes. Finally, if your RV is going to be sitting for a while, winterize it by turning off the water supply and adding some RV antifreeze to the lines.
If you're still having trouble, it's best to get professional help. They will likely be able to offer more tips and advice than what is available online or in manuals.
Thanks for reading! -Oliver Travel Trailers Team
Share and Enjoy !
Shares
The post 8 Tips for Dealing with Low Water Pressure in Your RV appeared first on Oliver Travel Trailers.
Read the Full Article
