So my kitchen faucet has become loose.  Has anyone tightened this particular one.  I don’t want to disassemble more than I have to.
Thanks,
3FFC701E-9307-47FC-9C38-50E40A538164.thumb.jpeg.2634cc9b345ceba74448ddc8c23fcee1.jpegEFD0390E-3338-4F12-B07D-2FB3CB15E8EC.thumb.jpeg.ba86f859db0617d038b75db284bcd83c.jpeg
John and Kim
SAME Here, in fact I was actually working on tightening it up, when I thought I would "Go To The Forum" and find a remedy.  and here i am...
Ours has worked its way loose since delivery/pickup many times.
You have a better picture than I was able to get.
I believe what we are seeing here is something like a "Delta Mounting Nut", on their single stem kitchen sinks.
Back off the 2 "tightening screws" about one turn, then hand tighten the "mounting nut" (you can see the threads) as tight as you can, then tighten up the 2 screws.
that should put enough tweak on the mounting nut to hold it in place.  on my delta sink at home, it has one tighten screw, so when tightened, it puts a little tweak but just on one side, but that has held for years and is used a hundred times a day...
I am going to work on mine now and see if I can get it tightened up before we leave for "VACA"...
My Visited North America Map
I backed off the tension screws 3-4 rev's and was able to get another 1/4 turn on the mounting nut.  Then re-tightened the 2 tension screws.
the tightening screws appear to grip/anchor into the underside of the countertop, so that may end up being problematic, as it does not appear to have a metal washer between under side of sink counter and the mounting nut.
A large Philips head with a 10-12" shank could possibly make it easier.
One more item checked off before we leave.
B~Out
