Hi all, I used our outside shower and noticed water leaking from two steel scuppers by the outside shower.  Anyone else experience this?  TIA.  John
No leak with the shower off? Sounds like the shower hose is loose/leaking where it attaches to the faucet, or the shower hose is cracked. Look under the street side bed.
Thanks
John,
Another thing to consider, if your Ollie is parked slightly nose down a leak anywhere along the curb side plumbing can find its way to those front scuppers. Be sure and check all your plumbing connections under the rear curb side bed. I had a compression fitting come loose and the water traveled all the way up to the front scupper and this is where I noticed the drip. I hand tightened the compression fitting (check them all) and no more drip.
It does sound like your leak is more in the shower plumbing area.
Patriot🇺🇸
