John and Debbie Posted June 6, 2023 Posted June 6, 2023 Hi all, I used our outside shower and noticed water leaking from two steel scuppers by the outside shower. Anyone else experience this? TIA. John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Steph and Dud B Posted June 6, 2023 Posted June 6, 2023 No leak with the shower off? Sounds like the shower hose is loose/leaking where it attaches to the faucet, or the shower hose is cracked. Look under the street side bed. 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
John and Debbie Posted June 6, 2023 Author Posted June 6, 2023 17 minutes ago, Steph and Dud B said: No leak with the shower off? Sounds like the shower hose is loose/leaking where it attaches to the faucet, or the shower hose is cracked. Look under the street side bed. Thanks John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Patriot Posted June 6, 2023 Posted June 6, 2023 John, Another thing to consider, if your Ollie is parked slightly nose down a leak anywhere along the curb side plumbing can find its way to those front scuppers. Be sure and check all your plumbing connections under the rear curb side bed. I had a compression fitting come loose and the water traveled all the way up to the front scupper and this is where I noticed the drip. I hand tightened the compression fitting (check them all) and no more drip. It does sound like your leak is more in the shower plumbing area. Patriot🇺🇸 1 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
