Posted on September 18, 2023
Hello everyone!  Does anyone know if a thermal camera will find moisture within the fiberglass Oliver walls or flooring (insulation or otherwise)?  I know a moisture meter will not work due to the aluminum inside the walls.
Thank you!
@NomadLife
Your Oliver forum personality shows that you do not own an Oliver Travel Trailer or any RV, so what is the nature or reason for your moisture question?
