Patriot Posted December 8, 2023 Posted December 8, 2023 A simple galley outlet “hack” which I wont take credit for. Someone on FB posted a photo of this 6” power strip and I don’t recall who. Anyway I ordered one. It just seems a little bit easier to plug in the coffee pot and toaster early in the morning.😴 Just passing it forward. Installs easily with 3m double sided tape sold separately. https://www.amazon.com/GE-Designer-Extension-Grounded-45190/dp/B07P889FHQ/ref=sr_1_8?crid=3EMUX18DKS0D2&keywords=triple%2Boutlet%2Bextension%2Bcord%2Bshort&qid=1702078039&sprefix=short%2Btriple%2Boutlet%2Caps%2C2082&sr=8-8&th=1 Patriot🇺🇸 6 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️Recent Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators SeaDawg Posted December 9, 2023 Moderators Posted December 9, 2023 Unless you're on 30 amps, I'm guessing you don't use all those appliances at once? Nice upgrade, so that you're not plugging/unplugging constantly. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
