Everything posted by TexasMarshall
Thanks. TexasMarshall
Is it possible to get a build list on my Oliver?
Hey Muppy, We always fill the fresh water tank & use the pump. City water can cause problems because of surging pressure. Good luck.
Welcome to the club Muppy.
I was looking for a unique place to go camping & I found Fort Clark Springs. A calvary Fort until after WWII when the Army did away with horse calvary and went too mechanized calvary. At one time there was 5000 horses at this Fort! The thing that drew me to this place was a beautiful spring fed swimming pool. 68°! Pretty darn cold. But during the summer when its 100°, 68° is not too bad. The campground is not the most beautiful but it’ll do. Lot of historical buildings on this Fort & interesting history.
On the airstream trailer the sacrificial annode was checked annually. I have removed the shower head & the sink heads & the water flow is the same. Nothing plugging up those. I removed the hose from the back of the toilet & checked the water flow. It’s definitely plugged up down stream some where after the kitchen sink. Good water flow at the kitchen sink & outdoor shower shower! Thanks guys for all your help.
I’ve owned travel trailers since 1970 & never run into this! Our first trailer was a 10 year old air stream we inherited from my Dad. We kept it 15 years & it never had a water problem. It was 25 years old when we gave it to my daughter to live in at college. It’s still in the family & still has no water problem! Seems to me to be an Oliver problem!
We will not have the time to deal with this untill we return home July 20. Since we picked up our ollie April of 2018 it has been on the road, maybe 50 days at most. There has been no mods done to it. Definitely no kinked hoses. We have never touched the valves but we checked anyway & they are all in the right position. The problem in the cold water line has to be after the kitchen sink as we have water at the kitchen sink. And the hot water line has to have a problem after the kitchen sink. The cold & hot water lines both have a tee at the kitchen sink. The plug in the line i think is at those tees. Oliver techs r wanting to blame it on hard water? We have been no where we might have used hard water and if we had it would have taken thousands of gallons to plug those lines. Oliver has a problem & so do I & I’m not happy!
we were on our way to Ft Clark Springs & stopped at a rest area to use the facilities but restrooms were closed. Went to our Ollie to use the bathroom. Wife went, I went & noticed very low water pressure. Told wife the water pump was not working & I’d check it out when we got to the camp. Got to camp & started checking. Had water at the kitchen sink & outdoor shower but no hot or cold water in the toilet or sink. Turned off the pump & hooked up to city water. Same results. I got a problem. Please help!
Thanks. I think I might have that glue problem because the dirt really sticks & is difficult to remove! I’ll clean out that groove & see if that helps.
how do y’all keep the grooves on the edge of the floor clean? Dirt & debris stick in the grooves in my trailer. It’s a on your knees job to get them clean?
Split: Black valve hard to move
TexasMarshall replied to TexasMarshall's topic in Mechanical & Technical Tips
Thanks, followed your recommendation & it worked! Now that black water valve opens & closes very easily. Bought 1 can of the WD 40 silicone lube, pulled the wire out, sprayed as much as I could get in the sheath & then coated the wire as I put back in. Pulled it out again & put back in again while coating it with the silicone lube. Worked like a champ. -
The trailer is 10 months old. The cable is practically new. In the 10 months I’ve owned the trailer I’ve probably dumped 15 times at the most. If the cable is kinked or nicked, it was done the build at the Oliver plant. I’m gonna try lubing the cable first. I’ve talked to Ritchie, Service tech at Oliver & they will send a new cable if the lube doesn’t work. I think we got it covered. Ritchie says the black water valve is stiffer than the gray water valve due to the cable being a lot longer on the black water valve. We will see. -
I’m gonna try the motor cycle cable lube device. If that doesn’t work, I wonder how hard it is to change the cable? -
I’ve used the Thetford drain valve lubricant & keep some in the trailer. Doesn’t seem to help. -
Thanks! The valve does move easily when the cable is disconnected. If there is a problem with the cable, it’s been there since the trailer left the plant. I noticed how hard it was to open the very first time I dumped! A quality control boo boo on Oliver’s part. -
Got another question. My black water valve is hard to open. That long cable from the rear of the trailer to valve is the problem. When I disconnect the cable from the valve, it opens & closes easily. Y’all got some suggestions on making it easier.
Protecting the front of our Oliver
Is the automotive clear paint protection film easy to remove -
Thanks guys y’all r great. Much appreciated!
