In 2017 when we purchased Hull 254
I purchased these tools
You have inspired me to figure out which bits I need from the kit
Any suggestions for the size of the snap ring pliers
I thought of that method, but I’d have to purchase lugs
I’ll price it out
The bussbar appealed to me, because I could over think the idea
form the bar, tin the bar and then heat shrink
The offset cable seems more practical
Any advice on how to bend on offset into a copper bar to connect to the disconnect switch.
Also is 10mm x 25mm cu overkill vs 6mm x 25mm cu
The ampacity calculations are not clear to me
2017 Oliver
While staring at the wiring around the charge controller (trying to make sense of it).
I noticed this, after 7 years…
No wonder the hose on the outside shower seemed less than useful.
The temperature sensor is scheduled for removal, as the BMS tells temperature.
The weather has been unpredictable this year (50s followed by 20 below zero.
The BMS does shut down in the cold, the batteries clicked off just as we got home from Florida.
