Collier and Joan
    514
    2019
2,255 profile views
Collier and Joan's Achievements
Apprentice (3/14)
14
  1. I found out what was wrong with electrical in trailer. I open up the inline surge protector case and found a burnt wire, replaced wired, and 120 volt appliances and outlets worked, I still don’t understand even with a burnt wire the ems still showed no errors and 120 volts
  2. Ems is on normal, I did try bypass and nothing change other than ems screen going blank
  3. I will check, I did not get the inverter option I only have the converter and progressive surge protector
  4. My EMS shows voltage 120 E0 Everything was working at campsite- ac was on, then all at once ac stop working/ frig came off ac/ outlets all when dead Look at gfci- had not trip but would not test, circuit breakers did not trip, outside shore breaker did not trip Got home hook up to designated 30amp Rv hookup and still no change, EMS still showed 120/E 0 All 12v appliances work
  5. would the gfci going bad also cause the air conditioner not to work
  6. what amp size of gfci do I need, any recommendations
  7. Try flipping breakers no go, saw no scorching on connections, the end shows E0
  8. That’s correct at campground everything was working and then at the same time the air stop working and the outlets would not work, use the Klein at home not the campground, the 30 amp at home is a hookup in my carport for the trailer and has always worked, the ems shows voltage coming in/ 125
  9. While camping yesterday the a/c and 110 outlets stop working. The GFCI outlet under side bed table was not trip but would not work either (test and reset buttons wouldn't work). I was hook up to shore power and the EMS showed no error codes. No circuit breakers were trip, only items that run off shore power won't work, I do not have an inverter. Today after getting home last night (had to leave campground/ temp outside was 96) hook up to my 30amp power and still the same results. I have very limited electrical knowledge, I did plug in my Klein RT210 tester into all the outlets and they all were indicating hot/grd rev. Any help will be appreciated. 2019 Legacy 2 Hull 514
  10. As soon as I disconnect from tow vehicle, these 4 lights come on dimly lit on both sides of trailer.
  11. I need help, areas of patches of spotting on my gel coat are appearing. Need help identifying and what to do
  12. Still haven't been able to hook up with Oliver about valve lever but have order a new valve on amazon made by JR to replace, this brings up a question, what plumbing parts would you bring with you for breaks on the road
  13. I think the missing lever is the one upper right, I will call oliver in the morning
  14. Need help, started to winterize trailer, went to bypass water heater, lever is missing, look to see if it pop off due to vibration but it is no where to be found, Oliver might have remove it for some reason when doing yearly maintenance a few months ago, cannot find that type of fitting with that lever anywhere, any suggestions where to find one
