Roger
Roger's Achievements
Enthusiast
Enthusiast (6/14)
112
  1. I upgraded from a F150 to a F350. It was wonderful getting rid of the Anderson hitch and the F350 doesn't need sway control. However, the best part is driving down mountains is so much less stressful. That all by itself makes the bigger truck worth it.
  2. That is what I was thinking. Thanks for the clarification. I live outside Atlanta and we occasionally get cold enough to need to winterize but I would prefer not to use antifreeze. I take trips during the winter months and it is a hassle to winterize and de-winterize each trip.
  3. @jd1923 when you do step 10 do you have the air compressor attached to the Fresh Water inlet? Doesn't this go through the Fresh Water tank where it will need to build up pressure before it can blow out the lines. I don't see how it can build up pressure when the Fresh Water drain is still open? What am I missing?
  4. Do you blow all yhe lines or just the freshwater tank?
  5. Just flushing the city lines doesn't get rid of the anti-freeze pumped into the fresh water tank when the freshwater line was winterized. This is what I am interested in flushing, more so than the city lines.
  6. Looks good. Thanks.
  7. @Geronimo John you are correct. I meant to say the working load is 1/3 of the breaking strength. I can't edit my earlier post. @topgun2 can you correct my earlier post?
  8. John, I am glad it is working for you! One thing I have also learned about the unit is you MUST lift up the baffle at the top or it just doesn't work very well. Don't ask how I learned this (more than once 😁). I am thinking about removing the baffle so that I don't forget to open it in the future.
  9. John, Samsung has SmartTag which is an Android version of an Air Tag.. I'm not sure if they only work with a Samsung phone. I have 4, one of which I have hidden in my Oliver.
  10. John, I have been keeping it on the counter next to the sink. Roger
  11. John, Mine worked fine out of the box in my Oliver with no issues and has never tripped the breaker. I would suggest you return it and have Amazon send you a replacement - it sounds like there is something wrong with the unit itself. Roger
  12. John, Letting it stand for 24 hours allows the compressor oil and refrigerant to settle back where they belong so that you don't damage the dehumidifier. Roger
  13. Lithionics told me at the last rally that I should cycle the batteries. Discharge the batteries to their reserve voltage (i.e. until they quit working) and then recharge them. He suggested I run the a/c on battery until it quit as a quick way to run them down. This seems to have worked for me as my batteries now show similar life remaining. The rep said that the batteries don't really know their discharge state and use an algorithm based on recharge time, usage, etc. and sometimes get out of sync. There is another discussion about this here.
  14. @jd1923 This is a compressor dehumidifier. If you go through the pictures on Amazon, one of them shows this.
  15. @rideandfly I used the KNKA on a trip earlier this week in the Okefenokee Swamp where the temps were in the 50s and 60s and the humidity was in the 80% to 90% range and it did an excellent job keeping the humidity down.
