Nick R.
Nick R. last won the day on July 24 2021
Nick R. had the most liked content!
    612
    2020
Nick R.'s Achievements
Explorer
Explorer (4/14)
54
  1. I use four small throw pillows I picked up at WM I double them up for more support, easy to move around and stow if needed.
  2. Tejas Smokers is another company I worked with to get the tubing and quick disconnect fittings replacing the regulator on my grill. They were very helpful in getting it figured out and working great! https://tejassmokers.com
  3. I agree... I'm just thankful it was something I could do myself.
  4. Hi John, I'm a full-timer. I try to wash mine a minimum every two months, this seems to be plenty for me. Naturally, if under trees, etc. there's going to be more debris. I find it easy to do from my multi-function ladder and using an extension brush with my 2050 psi pressure washer, that I have with me all the time. NR
  5. Yes, and also with the help of my trained octopus!
  6. Hi mccrusn, My experience with the regulator on the Oliver is this; I run a Napolean TRAVELQ 285X BBQ. It came with an onboard regulator, but I got very poor performance due to the second regulator on the grill and could not grill! What I found is, I needed to remove the regulator on the grill and run a straight hose to my grill. I was able to find the right one at Camping World as shown here: https://www.campingworld.com/coleman-road-trip-conversion-kit-with-female-quick-disconnect-me66cp-115951.html#q=quick%2Bdisconnect%2Bhose&lang=default&start=2&cgid=maintain-your-rv%2Fpropane%2Fpropane-hoses-adapters After this modification, I can now run my BBQ no problem and get temps 400+ deg. You ONLY need the regulator on the Oliver, no others. Regulators are designed to allow a specific flow rate, adding another regulator will cause poor performance and not give you the desired flow you need. As you stated with your 20LB tank, you should be fine with the reg on that hose. I hope this helps! NR
  7. Hi Ralph! I'm sorry this happened, I hope its not going to be too much trouble getting it back where you need it. I agree with John E Davies, this is not the best solution for this type of application. Anytime you have sharp bends and pressure with these kind of straps, this is of course is going to be the result. A solid band of heavier gauge would be a better idea. I hope this doesn't slow you down! NR
  8. Hi Overland, that was my number one concern. If I do notice a spot, which is very rare for me, I just use a mixture of organic disinfectant/cleaner and it's a good as new. Samples are the best way to decide, I just went for it and I'm real happy with it!
  9. Hi Ray and Susan, I was able to find a discount coupon on the Internet before I placed my order, so I got it for less... don't pay retail, right? I knew the look I wanted, so I went for it and haven't looked back.
  10. Thanks SeaDawg! Yes, each tile is very thin with a 3M type backing. No problem behind my stove. I’ve had this on for almost 1.5 yrs and easy to wipe off. Very minor pealing in a spot or two but a very small drop of Locktite SG Gel and problem solved. Easy to clean, no staining. Actually better and safer than bare fiberglass. The stone will actually shield flames/heat infinitely better than without it. I don’t get a lot of splatter from my iron skillet, but it still looks as good as the day I installed it. The 3M backing plus the natural stone keeps the dining area around the window cool to the touch in summer temps in Las Vegas (118 deg), in addition the Ollie’s double insulation. Naturally, the metal window frame is still blistering hot inside in those temps. 👍
  11. Hi Everyone! In the past, I've seen talk in the threads regarding the low flow from the furnace to the bath vent, well, I experienced that too. Here's what I found after a little detective work... Well no wonder! It helps when you connect the duct together. Yes, it was never connected, no wonder I only felt a very faint breeze from the bath vent. This shot was taken looking toward the kitchen sink, directly under the galley sink. The only way I could access this was to remove the plastic vent cover under the galley sink to connect the duct together. If this had not been possible, then the ONLY way would be to destroy the cabinetry to gain access to it. This was my first view, not touching anything and snapping this photo after I gained access. As you can see in this shot, there is no duct sealant or sheet metal screws, only a lone zip-tie that could not have possibly held this together properly. Notice, I put a plastic bag underneath to get ready to apply duct sealant. This blue tape was on the duct in two locations, possibly to note that this needed to be corrected before this area was closed up? Prepping the floor so I don't get duct sealant all over the place. Here's a look inside through the vent access directly looking at the disconnected furnace vent. The proper solution... three (3) sheet metal screws to follow. Keeping it neat and clean and getting a good bond. All dry, ready for the sheet metal screws... Due to the extreme limited space and only able to work with one hand, I had to tape the screws to the vent and use a hand driver to get the three sheet metal screws in the vent. It was impossible to access the other side however this is more than sufficient, especially with a generous application of the duct sealant and what is to follow... Ah yes, after the duct sealant completely dried and three sheet metal screws, I wrapped the joint with real duct tape and finished it with a fresh zip-tie to complete the surgery. And there you have it ladies and gentlemen... mission accomplished! I later purchased some inserts for the vent ducts that allow me to open and close the amount of flow that I want from the furnace in the bath. I simply adjust the two in the galley to my desired comfort and I'm a warm, happy camper! BTW, the awesome folks at Oliver Travel Trailers were very kind and reimbursed me for the materials, so we're both delighted with the result! For anyone experiencing low/no flow to their bath, this is the very first place I would look. Simply remove the vent cover under the galley sink, carefully disconnect the duct and see if your distribution tee is properly connected. If it is, I would strongly recommend the adjustable registers that can be purchased for these vents, my Ollie did not come with them. You only need two (2) for the sink vent and the bed vent. They are approx. $10 ea. When I run my furnace, I adjust them and can get a good flow of warm air in the bath. Problem solved!
  12. No, not at all... there's still so much white that reflects from the light, I don't notice it. Maybe because I took the photos with the blinds closed and the LED's are on it may seem that way. It really makes it look "classy".
  13. Hi Everyone! It was time to spice up the Ollie, so I decided to add some contrast to break up that "sterile" look of all white in the kitchen and dining areas... So, I added some Aspect Frosted Quartz Stone! It's pretty easy to apply, it's a "lick 'em, stick 'em" product (peel and stick). It is "real" quartz stone, doesn't add too much weight but worth it's weight in looks! Here's what I come up with... There's lot's of flavors to choose from... here's the link where I got mine if you're interested. https://diydecorstore.com/product/aspect-peel-and-stick-stone-backsplash/
  14. Hi John, I think we've all kicked that can down the road, at least a couple times. You make perfect sense and with that said; I think you both would have no regrets enjoying great times you're both going to have in your new Ollie. When the storms blow and the elements are demanding, you'll both be safe, secure and comfortable in your little home on wheels. I personally belive an Ollie is an investment, you'll definitely spend less time being concerned about the quality of your purchase. When I bought mine sight-unseen, I stumbled upon Oliver Travel Trailers on the Internet and never looked back... I had never even been in one until the day I got mine. The worst that could happen is, your investment will hold it's value better than most and you'll have some great times along the way. Thanks John, for stopping by and reaching out! Nicky Ray
  15. Extra hose and fittings is a great idea and doesn’t take up much space or weight, that’s a great idea ScubaRx! Thanks Mike and Carol! 👍
