FLYnGATOR
Everything posted by FLYnGATOR
  1. During troubleshooting I did raise the nose. I probably exacerbated the problem! Best, Mark
  2. I apologize for not posting a resolution sooner. I changed the inverter circuit breaker for new. Hard to find. Home Depot website only. Charging issue resolved. My theory is a washboard road in and out of 11 Mile Reservoir State Park CO. Who knows?! Thank you for all your knowledge. Mark
  3. Having shower pan backup and slow draining with water from bathroom sink, lots of gurgling through kitchen sink, slow draining with grey valve CLOSED. Normal draining when grey valve OPEN. I read this post which made me remember I had used a power washer during washing the day prior. Hooked up shop Vac to roof vent for 5 min. Same result of about half gallon of water. Seems to have solved the issue. Thanks for posting!
  4. Thanks again for your expertise. Always nice to know if I’ve got the star link, I can get some technical help!
  5. I always got 60 to 90 minutes charging time before the breaker would trip. I will swap out the breakers to test the circuit when I get home
  6. Also discovered that the 25 amp inverter breaker Does not need to be on for the inverter from battery. The only way to get “shore power“ in is to have the breaker on
  7. I get about 60 minutes or so of charging before the breaker trips
  8. Update 25 amp inverter breaker still trips on normal shore power. So I don’t believe it was my generator. The breaker is tripping on thermo as it is HOT and resets after cooling. This occurs with and without the air conditioning on. Dialed the charger down to 80A Same result Mark
  9. Great explanation! Thanks so much for the information! I’ll keep you posted Mark
  10. While charging on the generator, the 25 amp circuit breaker on the Zantrex 3000 inverter keeps tripping. I’m running the generator and the inverter switch ON I’m using a champion 3400 W generator and running the air conditioner simultaneously. Could it be the charger and the air conditioner are pulling too many amps simultaneously tripping the breaker? I’m going to try charging only, with the air conditioner off and inverter switch OFF any thoughts? Mark
  11. The only extended Boondocking we have done so far has been three days in a heavily shaded campground in the great Smokies, Catatloochee Did not run AC, ran Max air fan at night , batteries ran down to about 45% we have the 640 amp hour batteries and 400 W of solar
  12. https://a.co/d/0MWDOHw
  13. Thanks for all the great info and instructions!! I believe I will wait until after our trip to install the port and use the alligator clips in the interim. I’ve ordered both the Renogy 200 and Zamp 190 suitcases and will return one of them. I want to see if the Zamp is worth almost 3x the cost of Renogy. Doubtful.
  14. Awesome! Thanks! I don’t know if it’ll will arrive in time to wire external solar port Mark
  15. I do not have the Zamp Solar Port. I ordered from the 2024 build sheet in October 2023. OTT had changed the Zamp solar port being included with the lithium platinum solar package, to a dealer installed option. Didn’t catch it until too late. After watching the video, I still have a question. Can I connect the solar panels via the alligator clip directly to the batteries without an integrated charge controller, utilizing the onboard charge controller? Or is the onboard charge controller only able to be utilized through the zamp solar port?
  16. A couple of questions that I couldn’t find an answer via the search topics. 1. Can I connect solar panels, which have an integrated 20 amp charge controller, directly to the batteries via the supplied alligator clips? 2. Is there a maximum wattage that can be added to my 400W onboard solar via an external port? Thanks ! getting ready to leave on an extended western trip. I thought I’d pick up a solar suitcase just in case, as much of our time will be boondocking. Mark
  17. Never heard of anything personally. I did see a video on YouTube of a camper chasing his trailer being stolen out of the campground. stopped them! https://a.co/d/8BlEZYa You can also add locking bolts to attach the bulldog coupler to frame if you’re really worried about theft. Best Mark
  18. Additionally, the handle is the same on the outside as the inside. No problems with the “foot slicer” as mentioned…unless you are a member of the Monte Python “Ministry of Silly Walks”
  19. The mirror appears to be attached with an adhesive, no clips, as used for the mirror inside the head. We’ve have had no issues with the handle catching on anything. It does take a firm push to engage the latch. It works best if you press the door rather than the handle. Best Mark
  20. Posted
  21. Thought I’d post a few pictures of the new bathroom door. I like the door, it is an improvement over past versions. It appears to be made of a composite material, as opposed to the closet and pantry doors. Smooth glossy finish on both interior and exterior sides. From the inside of the bathroom, it is translucent as you can see light around the perimeter of the mirror. nothing major. There is a drip “rail“ at the bottom of the door to prevent leakage, as well as a rubber gasket around the perimeter. My only concern is the latch. You must give it a firm push / pull in order for the latch to click fully closed. This may stress the handle over time. overall I like it. Time and closing technique will tell. Mark
  22. Exactly what I wanted to know, thanks! Have you ever run into an overheat situation on the trailer pump while refilling the onboard tank? Mark
  23. 2024-Elite-Build-Sheet 07072023.pdf 2024-Elite2-Build-Sheet 07072023.pdf
  24. New bathroom door confirmed with Josh White.
  25. Thanks!
