Everything posted by Derek B
Gary, I do not have a victron inverter yet but have thought about this install. My guess to the left of the pantry you only have a radio with a blank space above where the zamp controller would normally be installed. If I was installing a Cerbo GX display that is where I would put it. During my solar install I tried multiple attempts to get wires up along the left side of pantry from under street side bed and had no luck. I could not get anything any further than the line where the upper and lower hulls meet. The place where I found to easily fish wires thru was to follow along the ac drain tubing from attic to lower basement area. Once in the attic the wiring can be passed along the back of the street side upper cabinet and behind the radio area.
@Teaney Hull 292 there are 3 ongoing post on the forum right now about lithium up grades and I must admit I have gotten confused on what was said in each one. What I haven’t seen in your post is mention of disconnecting the charge wire for you 7 pin connection. Just want to make sure you don’t miss that requirement when going to lithium. It was discussed recently @tallmandan thread below, https://olivertraveltrailers.com/forums/topic/10748-epoc-lithium-keep-it-simple-upgrade-advice/
Epoc Lithium "Keep-It-Simple" Upgrade Advice
Derek B replied to tallmandan's topic in Ollie Modifications
@tallmandan nice work, you will see a huge improvement in capacity with your upgrade. -
Gary, sounds like you got a plan. I have the same PD charger and inverter only Xantrex 2000. Upgrading the inverter to inverter / charger combo can wait. What I typically do is turn off the circuit breaker for the charger and let my victron solar charge controller handle the charging since it is programmable. If solar is not keeping up for whatever reason I turn on the PD charger for top off. Will seek you out at the Rally to meet and check in on how your upgrade went.
In my case I also added solar and a battery shunt. Since I was already doing the wiring I added a positive bus bar under dinette and negative under street side bed to move the 6 ga wires out of the battery compartment. Not a hard job but takes a little more planning and wiring of course. -
@Patriot finally got around to looking a my cables used to parallel the batteries. They are 4/0 and 12 inches eye to eye, I do agree with @jd1923 though that waiting until batteries are installed are probably best option. From the day I placed my orders I had the cables in hand 2 days later. This is a pic of my install, i chose to center each battery on existing tie down straps using 3/4 pvc sheet I had left over from previous project as a spacer. On the sides of the batteries on long length of battery compartment I used strips cut from a cheap Walmart cutting board so everything fit tight. -
Gary, I will be at the rally and would be glad to give you a hand getting the new batteries hooked up at no charge. Would be helpful to determine whether you have the Xantrex inverter only or inverter / charger. If unsure post a picture and could help you identify. Also a pic of your current battery layout with good clear images of your current existing cables and connections.
You’re welcome and appreciate everyone’s feed back on this unit as well as additional information on the Atmos. Atmos still less than half the price of Oliver installed Truma. Wish there was another option for this upgrade without the additional fiberglass work. As summer approaches I will have to decide whether I can wait another year in hopes of more new units coming out or replace the Dometic.
One thing I have learned in the short time I have been on this forum. There are a lot of very smart Oliver Owners out there that know a lot about how different systems work. I can figure out the installation of a new AC unit and make it work but struggle with understanding the benefits of one over the other. Curious as to the boards thoughts on this unit as I still contemplate my upgrade from the Dometic Penguin. What I have been able to understand from the little I have found. 1. It should fit pre-existing hole and low profile. .5 inch taller than the Dometic. 2. Inverter ACs consume less power and would not need a soft start and run longer on batteries. 3. Quieter than dometic. 4. Would not be able to use drain tubes. 5. Uses same technology as home mini-splits. Seems to be a pretty new product with little info out there, https://www.turbro.com/products/greenland-13500-btu-inverter-rv-air-conditioner-with-heat-pump https://www.youtube.com/watch?v=8-psxzbpngA https://www.youtube.com/watch?v=rsnWzNLYGOY
@tallmandan check your connection. I believe as my trailer was you have eyelet terminal connections they are just bolted to auto post style terminals due to your batteries requiring this type. -
For the 7 pin 12 volt connection no need to disconnect anything under the vanity. Just disconnect the black wire from the 7 pin plug itself. Disconnect and tape the wire and tuck back into plug housing. Below is example of 7 pin plug diagram and how the plug looks when disassembled. Google replacing and rv 7 pin and should find plenty of videos showing how to pull back the plug housing. My battery compartment started out looking like yours but now looks like @jd1923. The smaller gauge wires can be brought inside the trailer by installing additional bus bars but may be more than you have in mind. For ease you can just stack multiple in same battery connections but may need longer bolts then supplied by epoch. If your 4/0 gauge connections seem short you likely have some extra length of cable of cable on inside of trailer under bed. The large 4/0 negative cable should be going directly to your inverter or a shunt if installed. If so you can pull some of the length into battery compartment by loosing the grommet in battery bay. Hope this helps. -
I disconnected the black wire from the 7-pin connector itself. Pulled back the connector housing, disconnected and taped the wire and tucked under housing upon reinstallation. The other end is still connected at the bus. -
I know this is the 4/0 cable I used, very flexible. I can’t seem to find my order in my email. When I get a chance will take some measurements and post. -
Like @jd1923 I went with the 2 - 300AH Epoch, I did need new cables for the parallel connections. My cables from my old lead acid batteries were too short. Like you I did not have the tools to crimp the big lugs and didn’t want to purchase for one job. Look up batterycablesusa.com, they will make cables in any length and gauge you want. I did a few different orders during mods for solar, adding shunt, and batteries and every order shipped within a day of me placing it. -
CO/propane gas detector replacement
Derek B replied to rideadeuce's topic in Mechanical & Technical Tips
I did this swap few weeks ago and immediately noticed the same thing, however once started tracing the red wire back and pulled back some of the wire loom found the red wire is one wire coming from power source with a y splice to make 2 red wires. I just cut the red wire at the splice and ran 1 red to new detector. -
You are correct, still requires the display but does also have Bluetooth feature for the victron app. The smart shunt is Bluetooth only with no display.
Prior to doing some upgrades on my electrical I had the opportunity to look at a 2025 on dealer lot near us and snapped a few pics. It does have a smart shunt.
For those ready to upgrade to Lithium 15% off Epoch for Black Friday. Epoch site code is BF2024 and where @jd1923 purchased Renewable Outdoors code is Epoch15. Both offering free shipping. This makes the 460AH Essential Heated and Bluetooth $1104.15 and the 300AH $849.15 each.
- 1 reply
- 1
Thanks John, yes I think the Epoch essential 460ah at $1299.00 (with likely 10% discount) is a no brainer. I am still hoping the 300ah come down a bit more so with 2 can go 600ah vs 460ah. If they do not will likely just go with the 460. Not sure the extra 140ah is worth the $700.00 price difference.
Thanks John, will take a look, the Epochs would definitely be my first choice when switching over to lithium.
Not sure, I have never measured it with anything, but I can tell a big difference in the way it feels inside after being closed up. Your question has me curious now. Will have to look into taking a measurement.
We use a similar one from Amazon, In our humid environment the tank fills up in about a week. Has worked very well. Prior to this I was buying damp rid every 2 weeks.
Thank you @Ronbrink, Great to meet you as well. Your modifications to your trailer are top notch and enjoyed discussing and looking at your Atmos install. Definitely seems to be another great option for Oliver owners wanting to move away from the Dometic. I do plan to try and catch @jd1923 while here to talk battery upgrades. LiTime running great sales right now. Still have not seen any price changes for the Epochs. Maybe Black Friday? Will wait it out another month and make a decision.
Victron Smart Shunt - alternative to the BMV-712
Derek B replied to Overland's topic in Ollie Modifications
@Wayfinder here is a pic of my shunt and bus bar install. Sorry for crude labeling. On the road using my iPad. The shunt lugs include the inverter negative, batt ground, and solar negative and a 4/0 jumper.
