Mark Meadows Posted March 16, 2024 Posted March 16, 2024 Hi all, Picked up my Oliver E2 in August of 2023. Recently I’m noticing the sagging of the wet bath door so it drags at the bottom enough that the door won’t shut without a little help. Spoke with Mike at Oliver support and he mentioned they have had some bushings going out on some of these. Does anyone have a DYI fix for this ? Taking it 2000 miles to their shop gets a little pricey. Mike suggested taking it to an RV repair shop locally but if I can fix it on my own I will. thanks for any information you all might be able to pass on! Mark Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
dewdev Posted March 17, 2024 Posted March 17, 2024 Can you go to one of the new Oliver authorized sales-service centers near you? 1 2018 Oliver Elite II, Twin Bed, Hull #354, new 3- 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators SeaDawg Posted March 17, 2024 Moderators Posted March 17, 2024 Ours "sags" if we're not level. (2008) Even the long piano hinge can't compensate for that. Can't say that that is your issue. May be something else. Best of luck. What year is your trailer? 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Mark Meadows Posted March 17, 2024 Author Posted March 17, 2024 1 hour ago, dewdev said: Can you go to one of the new Oliver authorized sales-service centers near you? I’m in Southern California and I think the closest is in Oregon so it wouldn’t be very economical Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Moderators SeaDawg Posted March 17, 2024 Moderators Posted March 17, 2024 Does Oliver still use a piano hinge on the door? 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Mark Meadows Posted March 17, 2024 Author Posted March 17, 2024 9 hours ago, SeaDawg said: Does Oliver still use a piano hinge on the door? Yes I believe that’s what it is. One long hinge that runs top to bottom Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
dewdev Posted March 17, 2024 Posted March 17, 2024 @Mark Meadows FYI, I see there is a dealer in Utah. Not sure if that is closer to you than Oregon. A list fo dealers is on the Oliver web site. 1 2018 Oliver Elite II, Twin Bed, Hull #354, new 3- 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Mark Meadows Posted March 17, 2024 Author Posted March 17, 2024 21 hours ago, SeaDawg said: Ours "sags" if we're not level. (2008) Even the long piano hinge can't compensate for that. Can't say that that is your issue. May be something else. Best of luck. What year is your trailer? It’s a 2023 Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
