Wandering Sagebrush Posted April 18 Share Posted April 18 I didn’t find anything in threads about removing window screens, I thought I’d ask before breaking anything. Any guidance on the secret handshake of screen removal? Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L Link to comment Share on other sites More sharing options...
Townesw Posted April 18 Share Posted April 18 (edited) Do this from the inside. Remove shades. Slide screen to middle of window frame. Grasp lower left and lower right corners of screen frame. Lift the lower corners at the same time so that the bottom of the screen frame clears the track. Pivot the lower edge of the screen frame towards you and drop the top edge of the screen frame out of the top track. The rear screen is different. It has 2 clips on the bottom and 2 clips on the top. If trailer is not on fire, gently pull on the bottom frame until clips release then the top of the frame will fall free. The rear screen does not fit in a track so note the positions of the clips before removing the screen. If trailer is on fire, grab the red trapezoidal shaped tab, yank the screen out, fling it to the side, then dive head first out the window. Edited April 18 by Townesw 2 6 Bill and Martha 2018 LEII Hull 313 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
Wandering Sagebrush Posted April 19 Author Share Posted April 19 BLUSH!!! I knew the frame needed to come out, but for some reason the screen didn’t want to move (there was a lot of sand and dust from our DVNP dust storm), but a few gentle taps with a ball peen hammer freed it up. The glass is even still intact. Thank you! 1 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L Link to comment Share on other sites More sharing options...
