The screw in my faceplate fell out and left home.
Two questions
1) Would a Home Depot carry a screw like this?
2) What would be a good glue to use on the screw to hold it in place?
I am told not to use Loctite. I need a tiny bit larger thread.  The screw is not biting into the fiberglass.  The hole is wallowed out.
@HDRider …or replace all 4 screws with aluminum plusnuts like these. image.jpeg.7e60ff61c3c754ba0da1021316e078f7.jpeg
……or these should also work well
https://www.facebook.com/share/v/QTPdcUrjpg3mfQu2/?mibextid=I6gGtw
**Sold😞**
Two questions
Take the screw to Home Depot, Ace Hardware, or other hardware store and you should find a similar screw, just get a slight larger screw. You might purchase 2 different sizes to insure one grabs the fiberglass. That is very strange. Did you remove the inverter face for some reason previously?
Edited by John Dorrer
missing word
Use a wood toothpick and a bit of Tightbond glue in the hole.  Don't over tighten it.  Replace the other screw and they will match.
Edited by Geronimo John
Nope
