Wandering Sagebrush Posted May 4 Share Posted May 4 (edited) I was doing a bit of cleaning today, and managed to pull a shade frame clip and screw out of the window frame. My old “use a toothpick” as a shim didn’t quite do the job. I can always go to a bigger screw or more toothpicks, but I’m curious if anyone has ever filled a hole with epoxy, and then re-drilled. Inquiring minds need to know. 😇 Edited May 5 by Wandering Sagebrush Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted May 4 Moderators Share Posted May 4 3 hours ago, Wandering Sagebrush said: I can always go to a bigger screw or more toothpicks, but I’m curious if anyone has ever filled a hole with epoxy, and then re-drilled. Inquiring minds need to know. I've not tried epoxy for this application but I don't see why it wouldn't work. There really isn't that much pressure on these clips - at least after you get the frame secured by them. Besides, a little extra epoxy in there just might help to keep the window from leaking.😉 Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted May 5 Moderator+ Share Posted May 5 (edited) I have often successfully used super glue and baking soda to fill a hole in plastic. It will solidify into a substance that you can mill, drill, sand ect. Fill and pack the existing hole with baking soda. Put a few drops of super glue on top and let it soak in. It will shrink down somewhat as it hardens. Fill again until flush with the top of the old hole. Use a file or sand paper to obtain a flat surface. Find the center and drill the new hole. This stuff is really hard when cured and won't expand much. If you drill the hole too small it will shatter when you put the screw in. Do a couple of practice runs on something else before you try to repair the blind. If you get it right, I've never had one to fail. Edited May 5 by ScubaRx 1 4 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Wandering Sagebrush Posted May 5 Author Share Posted May 5 8 hours ago, ScubaRx said: I have often successfully used super glue and baking soda to fill a hole in plastic. It will solidify into a substance that you can mill, drill, sand ect. Fill and pack the existing hole with baking soda. Put a few drops of super glue on top and let it soak in. It will shrink down somewhat as it hardens. Fill again until flush with the top of the old hole. Use a file or sand paper to obtain a flat surface. Find the center and drill the new hole. This stuff is really hard when cured and won't expand much. If you drill the hole too small it will shatter when you put the screw in. Do a couple of practice runs on something else before you try to repair the blind. If you get it right, I've never had one to fail. That is interesting! I had not heard of it before! Thank you! 🙏 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L Link to comment Share on other sites More sharing options...
