mthom Posted 3 hours ago Share Posted 3 hours ago I recently bought a 2023 elite. There is water leaking around the edges of trim a/c unit when it rains. Does anyone have any experience with this? Link to comment Share on other sites More sharing options...
Jim and Chris Neuman Posted 3 hours ago Share Posted 3 hours ago Is your 2023 trailer still under warranty? If so, a call to Oliver would be an obvious first step. 1 Link to comment Share on other sites More sharing options...
mountainoliver Posted 2 hours ago Share Posted 2 hours ago I would remove the air filter and check the condensation drains. They pass through the air conditioner to roof seal on each side. There should be some sticky caulk around each tube. Also I would check the four hold down bolts. There’s one in each corner. To access these you’ll need to remove the inside cover/trim. I think that there’s six screws holding the cover. Don’t over tighten the bolts, just make sure that they are snug. 4 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax Link to comment Share on other sites More sharing options...
rich.dev Posted 43 minutes ago Share Posted 43 minutes ago 1 hour ago, mountainoliver said: I would remove the air filter and check the condensation drains. They pass through the air conditioner to roof seal on each side. There should be some sticky caulk around each tube. Also I would check the four hold down bolts. There’s one in each corner. To access these you’ll need to remove the inside cover/trim. I think that there’s six screws holding the cover. Don’t over tighten the bolts, just make sure that they are snug. Is this for the Truma or Dometic AC? 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Solar, 3000W Xantrex Inverter) Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
mountainoliver Posted 39 minutes ago Share Posted 39 minutes ago (edited) Oops, yes thanks for reminding me. That is for the Dometic air conditioner as supplied by Oliver for my 2017 LEII. I’m not sure if my suggestion is correct for the Truma unit. Edited 37 minutes ago by mountainoliver Clarification 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax Link to comment Share on other sites More sharing options...
