Ty J Posted July 28, 2024 Posted July 28, 2024 I was tired of the Shower door flexing and decided to try little upgrade. Cut out door from 4 x 8 FRP plastic sheeting. Picked up damaged piece from Lowes and cut out. It has made the door more ridgid and solid. Used Cauling on edges and glue on innter. Was afraid to drill anything. Seems very solid for now. Only issues are my skills are lacking on cutting and saw did get away from me on the bottom not quite a perfect line. Love how the new doors are a solid piece on newer models of olivers. 1 3 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Moderators mossemi Posted July 28, 2024 Moderators Posted July 28, 2024 Looks like you found a solution to your issue! Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
SNY SD UP Posted July 28, 2024 Posted July 28, 2024 (edited) How do you keep the water inside, with all the Clips, Clamps and Braces on it... Just Kidding, Our latched door evidently tweaked enough to open (under tow) and cracked the mirror or by slamming against the dinette stop... we only have 5 years BAD LUCK remaining. I must admit that the mirror glass only 'spidered', and did not fall from the door. Just applied 'Gorilla Tape" in a nice star pattern, and lived with it the rest of the way home. B~OUT Edited July 28, 2024 by SNY SD UP clarification #2 1 2 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Ty J Posted July 29, 2024 Author Posted July 29, 2024 Its sealed pretty well with glue inner layer and silicon outer layer. The flexing always scared me with the mirror in it. Love newer design on new models.Sorry about bad luck on yours. Thats terrible. 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Ty J Posted July 30, 2024 Author Posted July 30, 2024 The clamps were holding glue while it dried. Did not understand your question. Clamps are off. shower door is ridgid and glued with piece that could be removed if needed. Silicon caulking and thin layer silicon glue. 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
SNY SD UP Posted July 30, 2024 Posted July 30, 2024 Ty J, It was my Humor, which gets me in trouble every now and then. I really did understand that the Clips, Clamps and Braces, would come off before use. And we will be installing a tether of some sorts on the frame to bath door/latch, as it popped open again while under tow on our last trip, however nothing was damaged this time. B~OUT 2 1 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
