Dave Mazone Posted October 3, 2024 Posted October 3, 2024 Hello Ollie lovers, My refrigerator seems to be working, but the mode is flashing between "auto", and "DC" and "propane" simultaneously. The mode button and temp set buttons are unresponsive. The manual doesn't seem to address this issue. Can anyone explain what's happening and how I might correct it? Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD)
jd1923 Posted October 3, 2024 Posted October 3, 2024 (edited) 1 hour ago, Dave Mazone said: how I might correct it? You should post what fridge make/model. Yours will be a newer model than ours. It may not help, but first cut all power to it for 10 min or more. Trip the 120VAC breaker or no shore power, LP doesn’t matter. Pull the DC fuse or all DC battery power. Ours has a 40A DC circuit breaker for all DC circuits (have a flashlight ready). This will force a reboot. If it goes back the same way, likely the switch panel or a control board could be bad. Edited October 3, 2024 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steph and Dud B Posted October 3, 2024 Posted October 3, 2024 Your hull number is close to ours, so I suspect you have the Norcold fridge. That isn't normal behavior and we haven't seen that on ours. I suggest you call Norcold and create a service ticket with Oliver as well. Meanwhile, try what @jd1923 suggests. 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
