Galway Girl Posted October 3, 2024 Posted October 3, 2024 (edited) We’ve been on some bumpy roads in Nova Scotia and it caused an issue with our truma water heater. Symptom: Louder than normal water heater ignition. A loud whoosh or pop on ignition. Strong enough to blow out the flame. A smell of gas! Cause: Burner tube assembly had come apart on the end of the tubes by slipping out of the retaining slots (last tube on either end) Fix on the road: Removed the burner and regulator assembly and re-assembled by re-aligning and re-crimping the burner tubes into the frame. Time: 40 minutes Tools: Crescent wrench & pliers for gas feed 2 Different size torx bits for burner screws Steps: Turn off gas & let burners cool down Pull fuse for water heater Take pix of wiring ( for re assembly) Disassemble gas feed using backing wrench Disconnect various wires from plugs & headers ( Includes 2 screws to remove igniter) Remove 2 screws on front of burner/regulator assembly Slide out burner. Reassemble burners in slots and crimp end burners Reinstall in reverse order, checking for gas leaks before reinstalling fuse. Run water heater to test. Enjoy hot water ! The last right and left burner tubes had fallen out of the registration slots. That caused gas to flow from the two orfices directly into the burner chamber. ( A nice big ignition event that blew out the other burners.) I reassembled and crimped them back in place. video describes which tabs need to be crimped. IMG_0872.mov Edited October 3, 2024 by Galway Girl Spelling 5 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
rich.dev Posted October 3, 2024 Posted October 3, 2024 @Galway Girl thanks for the very informative post, sounds like this is an issue with the Truma water heater, if I remember correctly you guys had a similar issue before? Hope you guys enjoyed NS, we will be staying at a season spot just east of Truro when we return from Arizona next year April/May until October. **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Galway Girl Posted October 3, 2024 Author Posted October 3, 2024 (edited) Yes, the last issue was from Truma factory, improper torque on the regulated gas line into the burner. Nova Scotia was fantastic. view from site 54 at The Islands PP. Edited October 3, 2024 by Galway Girl Label 2 2 1 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Galileo Posted January 11, 2025 Posted January 11, 2025 Hey there, We’ve started having a problem with our Truma Aqua-Go water heater as well. I’m thinking it’s related to the problem you encountered. We DO get hot water - but the water heater is noisy - some noise I’d describe as “banging” or “thumping” - but that could well be the same as the “whooshing” and “Popping” you describe. I also don’t think that the heater is working on the “ECO” mode - as I don’t hear the circulation pump starting up in that mode, but perhaps just because the burner is not kicking on. I can’t see anything wrong by looking under the burner assembly with a flashlight while it is still assembled. I guess I’ll have to go through the process you describe just to verify that we don’t (or do) have the same issue you have with induction tubes being knocked out of place. Shame on Truma for making a device meant to be used in an RV driven over the road - and not having it able to hold together under the use for which it was (supposedly) designed…. VV 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Snackchaser Posted January 12, 2025 Posted January 12, 2025 I don't know about the noises, mine makes just a little noise. The circulation pump keeps hot water in the small reserve tank, so it's turned off to conserve power and gas in the ECO mode. Good luck, Geoff 1
Galileo Posted January 16, 2025 Posted January 16, 2025 On 1/11/2025 at 8:12 PM, Snackchaser said: I don't know about the noises, mine makes just a little noise. The circulation pump keeps hot water in the small reserve tank, so it's turned off to conserve power and gas in the ECO mode. Good luck, Geoff The sound of the circulating pump and the sound of the flame coming on are normal. If you’re outside and listening very carefully, you’ll likely hear the “ticking” of the igniter and a fan noise that keeps the combustion going in the right direction. Those are normal sounds. The Truma manual says that “boiling water” sounds means you need to descale. Popping, whooshing, thumping, or banging are abnormal sounds associated with improper combustion from gas burning in the wrong places. That was my tip-off to the problem. “Galway Girl’s” documentation of the loose burner tube problem is what prompted me to pull out the burner yo check the tubes. I was initially “disappointed” to see the times were all in place. “Nuts! Now what’s the problem!?” I thought. Flipping the burner over and seeing that big plume of soot on the bottom of the tubes and around the nut attaching the gas line to the manifold prompted me to check the nut. Loose. Could move it freely with my fingers. Though I didn’t see much in the way of “crimps” on any of the burner tubes. (They’re smaller than I was expecting - my experience being with 2 foot long tubes on household gas boilers.) Mine were all in place and tight. Still, disappointing that a premium gas appliance in a premium trailer apparently didn’t get designed or assembled too carefully. Gas burning where it shouldn’t be goes beyond “inconvenient” and well into “dangerous” and “liability” territory. We put a couple of thousand miles on our LEII every year, and I’ve had several things vibrate or shake loose causing failures. It just reminds me that a good, thorough “preflight” inspection is called for and know trouble areas need to be checked frequently. Ironically, the stuff they tell you to check - like wheel lug torque - never seem to have issues. Go figure. 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
John and Debbie Posted January 16, 2025 Posted January 16, 2025 1 hour ago, Galileo said: The sound of the circulating pump and the sound of the flame coming on are normal. If you’re outside and listening very carefully, you’ll likely hear the “ticking” of the igniter and a fan noise that keeps the combustion going in the right direction. Those are normal sounds. The Truma manual says that “boiling water” sounds means you need to descale. Popping, whooshing, thumping, or banging are abnormal sounds associated with improper combustion from gas burning in the wrong places. That was my tip-off to the problem. “Galway Girl’s” documentation of the loose burner tube problem is what prompted me to pull out the burner yo check the tubes. I was initially “disappointed” to see the times were all in place. “Nuts! Now what’s the problem!?” I thought. Flipping the burner over and seeing that big plume of soot on the bottom of the tubes and around the nut attaching the gas line to the manifold prompted me to check the nut. Loose. Could move it freely with my fingers. Though I didn’t see much in the way of “crimps” on any of the burner tubes. (They’re smaller than I was expecting - my experience being with 2 foot long tubes on household gas boilers.) Mine were all in place and tight. Still, disappointing that a premium gas appliance in a premium trailer apparently didn’t get designed or assembled too carefully. Gas burning where it shouldn’t be goes beyond “inconvenient” and well into “dangerous” and “liability” territory. We put a couple of thousand miles on our LEII every year, and I’ve had several things vibrate or shake loose causing failures. It just reminds me that a good, thorough “preflight” inspection is called for and know trouble areas need to be checked frequently. Ironically, the stuff they tell you to check - like wheel lug torque - never seem to have issues. Go figure. What is your "preflight" inspection? Is that in the manual or a list you made up? Thanks. John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Galileo Posted January 17, 2025 Posted January 17, 2025 Hi John, No, not in the manual. I think the manual deserves a re-write as it’s glaringly lacking in a lot of areas. I suppose that’s the nice part about this forum, as owners either a few miles under their belts can share experiences and help others fix their issues without having to do all the sleuthing from square one. A real “preflight” on a trailer like ours would be akin to a pre-launch on the space shuttle. There are just too many systems to check in 5 or 10 minutes - or even a couple of hours - to make sure that -everything- was perfect before a trip. The “basics” would likely be all the things you hopefully already check. I’m sure someone here has already made a list that’s as good as mine, so until I have one written and perfected, I won’t post one here. val 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
