If you are looking for a simple way to keep your 7-pin plug out of the dirt, I found this Plug Keeper on the RVUpgradeStore.com for only $3.99. Since I have a particular aversion to drilling holes in our Oliver, I wanted to attach it to the trailer tongue with VHB tape. However, the back of the plug keeper is hollow. So I made a backing plate from a piece of 1/8” black acrylic sheet to increase the surface area for better adhesion. Two 3/16” aluminum trifold rivets worked well to attach the acrylic to the plug keeper.
Mike
  • 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler
  • 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
 Another option that is also protected from rain:  stuff the 7-pin up between the fiberglass housing and the aluminum a-frame.  See photos below.
The other version of a 7-Pin holder widely used. Regardless of the type holder, it is good practice to use dielectric grease to further protect the plug contacts from moisture and dust intrusion.
