GlacierGirl Posted March 26 Posted March 26 The 2021 Owner's Manual mentions there are several "frame anodes" which may occasionally need replacing (pg. 98). Where are those sacrificial zinc-anodes? Barb Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
Golfnut Posted March 26 Posted March 26 They are mounted on the alum. Frame about the size of a nickel with a rivet holding it, i think. There are several of them? 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Galway Girl Posted March 26 Posted March 26 (edited) If you look in the wheel wells you see them where the steel reinforced frame touches the aluminum frame. They are about the diameter of a quarter. Edited March 26 by Galway Girl 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
GlacierGirl Posted March 26 Author Posted March 26 Thank you, @Golfnut and @Galway Girl! I wonder how we know when they need replacing... and where one buys these anodes.🤔 I've never before heard folks talk about these. Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
Galway Girl Posted March 26 Posted March 26 (edited) The reason they are installed is that Oliver's main frame is Aluminum, but the axles are mounted with a reinforced steel frame. Where those two metals meet there could be corrosion unless some other "sacrificial" item is added touching both steel and aluminum. Due to electrolysis, the zincs dissolve away and will look ratty and crumbled so you see it when it's time to replace them. That can take a very long time on the Oliver hull unless you are driving in wet/salty conditions. (Like maybe 10 years or more.) They are available at most boating supply stores or online as "round sacrificial zinc". $3 each. The factory service center also has them in stock and can mail you them if needed. The round ones shown are often used on outboard motors which are in salt water and fresh water...thus available at marine suppliers. Take a look at the 1:35 mark in this video on the chassis construction to see the actual installed anode. Hope that helps. CS Edited March 26 by Galway Girl 2 4 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
GlacierGirl Posted March 26 Author Posted March 26 42 minutes ago, Galway Girl said: will look ratty and crumbled so you see it when it's time to replace them. 43 minutes ago, Galway Girl said: They are available at most boating supply stores or online as "round sacrificial zinc". $3 each. The factory service center also has them in stock and can mail you them if needed. The round ones shown are often used on outboard motors which are in salt water and fresh water...thus available at marine suppliers. Thank you so very much for explaining what I should watch for, and where to purchase. You gave a helpful explanation.😊 Barb 1 Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
Moderators SeaDawg Posted March 27 Moderators Posted March 27 In the boating world, they're called sacrificial zincs. Just like the anode in a standard 6 gallon water heater, they are made of less noble metal, and protect the important and superior metal parts by "dying/eroding" first. As @Galway Girl explained, when they get ugly, replace, and you're protecting your frame. cheap, and easy peasy. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
GlacierGirl Posted March 27 Author Posted March 27 Thank you all! I seem to be learning something new every day about Olivers! 1 Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
DanielBoondock Posted May 15 Posted May 15 tl/dr, the physics is galvanic corrosion, which are ‘phantom’ currents caused by having two connected dissimilar metals. It’s the valance electrons - just the electrons in the outer shell, which leads to a potential difference, so they’ll flow back and forth from high potential to low potential, and eating away at the metal in the process. I believe accelerated when in a high ionic environment like salt water (ocean water, or salted roads). As SeaDawg mentioned you have a less noble metal which sacrifices itself … I suppose because it’s at a lower potential so ‘pulls’ the currents it’s way. In this application though I’d expect little to no corrosion for most people which is why they use such small zincs. Makes me wonder why Oliver has a galvanized axel subframe, maybe just Dexter recommendation, but they’d still have the issue anyhow with the steel axels. The other type of corrosion you’ll get is filiform on the aluminum frame. Oliver Elite II Twin (order late summer for MY2026)
