The 2021 Owner's Manual mentions there are several "frame anodes" which may occasionally need replacing (pg. 98). Where are those sacrificial zinc-anodes?
Barb
Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota SequoiaAZARCOFLGAIDKSLAMSMOMTNMOKPASDTNTXUTVAWY
They are mounted on the alum. Frame about the size of a nickel with a rivet holding it, i think. There are several of them?
spacer.png2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
IMG_3540.jpeg.97ee2f9896c71d84ae27fc9caf04d083.jpegIf you look in the wheel wells you see them where the steel reinforced frame touches the aluminum frame.   They are about the diameter of a quarter.
Edited by Galway Girl
Thank you, @Golfnut and @Galway Girl! I wonder how we know when they need replacing... and where one buys these anodes.🤔 I've never before heard folks talk about these.
The reason they are installed is that Oliver's main frame is Aluminum, but the axles are mounted with a reinforced steel frame.
Where those two metals meet there could be corrosion unless some other "sacrificial" item is added touching both steel and aluminum.
Due to electrolysis, the zincs dissolve away and will look ratty and crumbled so you see it when it's time to replace them.
That can take a very long time on the Oliver hull unless you are driving in wet/salty conditions.  (Like maybe 10 years or more.)
They are available at most boating supply stores or online as "round sacrificial zinc".  $3 each.
The factory service center also has them in stock and can mail you them if needed.
The round ones shown are often used on outboard motors which are in salt water and fresh water...thus available at marine suppliers.
Take a look at the 1:35 mark in this video on the chassis construction to see the actual installed anode.
Hope that helps.
CS
Thank you so very much for explaining what I should watch for, and where to purchase. You gave a helpful explanation.😊
Barb
In the boating world, they're called sacrificial zincs. Just like the anode in a standard 6 gallon  water heater, they are made of less noble metal, and protect the important and superior metal parts by "dying/eroding" first.
As @Galway Girl explained, when they get ugly, replace, and you're protecting your frame.
cheap, and easy peasy.
Thank you all! I seem to be learning something new every day about Olivers!
  • 1 month later...
tl/dr, the physics is galvanic corrosion, which are ‘phantom’ currents caused by having two connected dissimilar metals. It’s the valance electrons - just the electrons in the outer shell, which leads to a potential difference, so they’ll flow back and forth from high potential to low potential, and eating away at the metal in the process. I believe accelerated when in a high ionic environment like salt water (ocean water, or salted roads). As SeaDawg mentioned you have a less noble metal which sacrifices itself … I suppose because it’s at a lower potential so ‘pulls’ the currents it’s way. In this application though I’d expect little to no corrosion for most people which is why they use such small zincs.
Makes me wonder why Oliver has a galvanized axel subframe, maybe just Dexter recommendation, but they’d still have the issue anyhow with the steel axels.
The other type of corrosion you’ll get is filiform on the aluminum frame.
Oliver Elite II Twin (order late summer for MY2026)
