Hello again,
I recently purchased a TST TPMS system that includes a booster/repeater to get the signal to realiably link to  the head unit in my truck.  I am going to install it in the trailer this weekend and my thoughts are to include it in the Rear Camera circuit as both the rear camera and the TPMS will be powered up at the same time.  The power switch for the Rear Camera is located on the Entry Switch Panel but is not tied to the Master Light Switch (it can be on when the Master Switch is off).  Which DC fuse is inline with the rear camera switch- F2 Electronics?  F5 Main Lights? or is it something different?
Thanks for the help.
Edited by EurekaJ
Jay D
Northern Virginia
U.S. Coast Guard (Retired)
2024 Toyota Tundra (Gumby)     2022 Legacy Elite II, Hull #1056  (Pokey)
According to the 2022 LE2 manual, the rear view camera is powered by f-2, a15A ATC fuse with a tan 14G wire.
IMG_1415.thumb.jpeg.9e1523a6eef63a5a09fa4da8c0791000.jpegIMG_1417.thumb.png.6d503df03fc38a7fc92281351a67347a.png
Thank you - I actually did refer to the manual, I guess I just didn't look closely enough.  I was only looking at the fuse panel descriptions on the latter of the two pages you shared and did not look closely at the panel layout on page 35 of the manual.
Jay D
Northern Virginia
Eurekaj,  To use the camera switch for your TPMS Signal Booster, you will have to tap into the "switched" camera power circuit, not the fuse.  Check out the modification titled "Turning on the rear camera automatically."  It has instructions and pictures for tapping into the camera circuit inside the attic, which is easier than running a wire to the camera switch.  It also shows how to connect directly to the Electronics fuse if you decide against the switch and just run a hot wire.
https://olivertraveltrailers.com/forums/topic/10461-turning-on-the-rear-camera-automatically/
Cheers!  Geoff
