The hand piece on our outside shower has pinhole leaks along a molding joint, probably my fault.
Does anyone have a source, or knows who made it?   I did create a service ticket, but have not yet heard back.
Thanks
Hull #364 - The Roadrunner
2023 F350 CCLB SRW 6.7L
I believe it's a Scandvik. On ours the screw-on part cracked, likely from over-tightening. This is s good replacement:
https://www.amazon.com/dp/B00AJVE86M/
Edited by jd1923
42 minutes ago, Wandering Sagebrush said:
Unfortunately, ours is different.  The hand piece has the female side.
You might want to take a look HERE - there are a number of these shower heads that have the same kind of shut-off valve as the original plus several that have a female fitting and extra hose or even some with different spray heads.  But, be careful that anything different will still fit inside the compartment without causing you additional problems.
@Wandering Sagebrush The one I linked above looks slightly different but is an equal replacement. My original one was the same as yours. They both work the same way in that the handle will pause the water flow. The new works like the original, looks nicer and the rubber seal doesn't leak!
