jd1923 Posted December 21, 2025 Posted December 21, 2025 Found these cool decorative emblems that have helped with repairs and mods. Any emblem you like could help cover up where needed. Last year I upgraded the OEM inverter. It had a remote switch, requiring OTT to cut a 2 1/2" square hole in the fiberglass below the pantry shelf. Now we have an emblem of the Arizona state flag in that spot. Just recently, I removed our Dometic A/C and thermostat. I decided to relocate the new furnace-only thermostat under the pantry. That way we could set temp while lying in bed, nice! WOW, what a mess under the old thermostat! There was even a broke-off screw in the wall, like the installer tightened it so hard the head broke off! I used a Dremel to file down the steel screw flush. I mounted the new thermostat, drilling one 1/4" hole for the wires, and mounting using 3M VHB 4950. One small hole is all you need! 😎 This time we went with the flag of the great state of Texas! @Mike and Carol should like this! We lived in Texas for 9 years. It's where our son grew up, went to school, played sports and he stayed for college. We also have a Red-White & Blue theme for our Oliver, so the Lone Star state flag is perfect. Sure looks a lot better! These are really decent quality emblems, 3 3/8" diameter an 1/8" thick and reasonable cost. I chose the semi-flexible models. They have the US flag, the Thin Blue Line, Army, Navy, every one of the 50 state flags and many more: https://www.amazon.com/dp/B09GH2TC75/?th=1 https://www.amazon.com/dp/B09G8SWZ42/?th=1 1 5 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted December 21, 2025 Moderators Posted December 21, 2025 7 hours ago, jd1923 said: This time we went with the flag of the great state of Texas! @Mike and Carol should like this! We lived in Texas for 9 years. It's where our son grew up, went to school, played sports and he stayed for college. We also have a Red-White & Blue theme for our Oliver, so the Lone Star state flag is perfect. Sure looks a lot better! We like both of those having lived in AZ and TX. Our daughter graduated from NAU in Flagstaff while we were there and we have spent much of our camping time in AZ. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators Wayfinder Posted January 13 Moderators Posted January 13 I'll need to do research on that remote thermostat. Not sure how they "separate" between furnace and A/C. Lots of digging into things, learning more and more. Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
jd1923 Posted January 13 Author Posted January 13 2 minutes ago, Chris Scarff said: I'll need to do research on that remote thermostat. Not sure how they "separate" between furnace and A/C. Going to a new A/C you have remote control for that. I added a heat-only furnace thermostat, so just ran two wires from under pantry around rear of basement to furnace. All original wiring for Dometic was left in the walls (not that I’d ever use it again)! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Wayfinder Posted January 13 Moderators Posted January 13 Yeah, I do want a new A/C too. Darn it. Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
