HDRider Posted 5 hours ago Posted 5 hours ago I learned something today. You have to take the bumper off to remove the spare tire cover. I sure am glad I am home on a cool sunny day, and not on the shoulder of I40 in the rain. Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Geronimo John Posted 4 hours ago Posted 4 hours ago That's a new one. It certainly was designed to just lift the license plate and remove the big nut. The cover can then be removed with the spare tire still attached to Ollie. Kindly post a picture. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
HDRider Posted 4 hours ago Author Posted 4 hours ago 5 minutes ago, Geronimo John said: That's a new one. It certainly was designed to just lift the license plate and remove the big nut. The cover can then be removed with the spare tire still attached to Ollie. Kindly post a picture. GJ I'm past the picture taking. It is not the spare tire in the way. The bumper is in the way. I'll take a pic when I put it back together. Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
HDRider Posted 4 hours ago Author Posted 4 hours ago I am terrible when it comes to reading instructions, especially when it seems like a simple task. I just checked the Owner's Manual. No mention of the bumper. Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Geronimo John Posted 4 hours ago Posted 4 hours ago (edited) Yep, that's the way it's done by about 1500 of us. (1500 is my guess as to the number of us with 16" tires.) Some thoughts come to mind. With the downsize of the tires from 16" to 15" was the design changed for the tire removal that would cause your difficulty? If it was, if you were to reduce the pressure in the spare tire to allow a slight reduction in the diameter would that make a difference in your situtation? Was your spare tire changed to a larger size? (Not likely with a 2023 OTT. I believe that from about 2018 to the rim size change, the spares were the same tire as the 4 on the axles. But that is just an assumption.) Best of luck. GJ Edited 3 hours ago by Geronimo John typo TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted 3 hours ago Posted 3 hours ago (edited) 29 minutes ago, HDRider said: I am terrible when it comes to reading instructions, especially when it seems like a simple task. I am too. What usually gets me to actually read the instructions is I run into a brick wall. Just as you did. Then I'll post it to the forum. Just as you did. So no worries. Please do post a pick, one of us out here will figure it out. GJ Edited 3 hours ago by Geronimo John TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
dewdev Posted 2 hours ago Posted 2 hours ago @HDRider Jeff: I do not think the bumper needs to be removed. On my OTT, Elite II, the trailer hitch receiver needs to be removed. 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
