J-Rhett Posted September 18 Posted September 18 I searched a lot of content and couldn't find anything like this. Do I have a plugged water line? Kitchen faucet and outside shower work great on fresh water and on city water. But the bathroom sink and toilet have barely a dribble. Before we went out to camp the water system was ok. After traveling just 20 miles or so the bathroom water doesn't work. I found plastic shavings a couple of years ago in the toilet inlet filter. I haven't checked it but that wouldn't plug the sink too. The plastic came from when they post drilled the tank a few year ago I think. I really don't want to make a trip to Hohenwald and back as it's about 760 miles round trip and diesel is hehehe. I know not much about how to clean water lines inside the double hull. How do I attack this problem? Hints? I won't be camping anymore this year anyway. Rhett & Dory Hull #186 2017 J-Rhett Oliver Legacy Elite II (Irog) 1995 Ford F-250 x4 Turbo Diesel Trek Bikes, Hobie Cat Kayak
jd1923 Posted September 18 Posted September 18 (edited) 11 hours ago, J-Rhett said: But the bathroom sink and toilet have barely a dribble. Before we went out to camp the water system was ok. Is the hot water also blocked at the bathroom sink? (They are separate lines.) If cold only, there is one line that feeds the bathroom (see plumbing schematic). What I would do first is blow air through all of your lines. Bypass your hot water heater first. I do this to winterize. Air will empty the lines and perhaps could move an obstruction. I made this tool to connect to the City Water inlet. You'll need a decent air compressor with good air volume. Set compressor pressure to 50 PSI which is your water pump pressure. Given it's both the toilet and bathroom faucet, it cannot be the toilet filter or the faucet restrictor. If air does not help, you could try it in the reverse direction. Take off the faucet head and with another attachment blow air from the bathroom faucet back. Hope this helps! Best wishes, JD Edited September 19 by jd1923 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
J-Rhett Posted September 23 Author Posted September 23 Great! Thanks. I had just come to your exact conclusion. I was going to try vinegar first, but now I think it's better to blow the lines. And yes, both the hot and cold lines are plugged. I think I already have an adapter that fits the female thread with air on the other end. I appreciate your help. Winter coming on and time is running out before we leave for the Philippines. And the diesel would cost about $325 to go 380 miles each way to Hohenwald. 1 J-Rhett Oliver Legacy Elite II (Irog) 1995 Ford F-250 x4 Turbo Diesel Trek Bikes, Hobie Cat Kayak
jd1923 Posted September 23 Posted September 23 3 hours ago, J-Rhett said: And yes, both the hot and cold lines are plugged. And the diesel would cost about $325 to go 380 miles each way to Hohenwald. Rare situation that hot & cold water flows through the kitchen sink and outside shower but not in the bathroom, with the same issue at the toilet! Did you do any work inside the bathroom vanity recently? I would start by removing the bathroom faucet/shower head and the toilet filter (again). Either these endpoints are the issue or somehow you have two internal obstructions on hot & cold lines somewhere past the water pump and hot water heater. It' won't hurt blowing air but what would cause these two obstructions at the same time? 1700 miles one-way to Hohenwald from AZ. Today this roundtrip would cost over $1,500 in diesel fuel. It's never an option for us. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
