Mac Posted November 30, 2019 Posted November 30, 2019 I'm having great difficulty getting the wall mounted thermostat to find the "auto" furnace mode. It wants to use the a/c unit instead of the furnace. Any ideas how to get it to cooperate? My unit is #264, elite Ii.
AndrewK Posted November 30, 2019 Posted November 30, 2019 If your thermostat is like ours (A Dometic Digital - Hull #468) and you only want the furnace to operate, you need to set the thermostat to heat. In this setting the furnace will cycle on and off based on the temperature you set. Andrew 2019 Legacy Elite II 2018 BMW x5 35d
Mac Posted November 30, 2019 Author Posted November 30, 2019 Andrew, thanks for the reply. We are camping this weekend and are trying to make the cabin a little more comfortable. Our Ollie's are practically family, separated by just 2 hulls (though ours was adopted Nov 1, 2019 from the original owner who just didnt want to take care of it any longer). The day we took delivery he told me the thermostat is "pretty finicky." Having never cared for an RV, let alone an Ollie, it's ALL a learning experience at this point. When this controller shows "heat" it always (so far) turns on either the a/c and/or its heat strip. However, once every blue moon it will magically display "auto" and "furnace" at the same time and then the furnace works, but only for a single heat cycle...not afterwards. I'm not sure what I'm doing incorrectly as there are very few options on the thermostat from which to choose.
AndrewK Posted November 30, 2019 Posted November 30, 2019 I am not with our trailer to look for you. I thought it was "Heat" but perhaps it was "Furnace". Do you have that option? "Heat" maybe the heat strip in the A/C. If that is the case, that may be the answer to your problem. Sorry if this did not help, Andrew 1 Andrew 2019 Legacy Elite II 2018 BMW x5 35d
AndrewK Posted November 30, 2019 Posted November 30, 2019 Mac, I went on YouTube and watched a couple of videos. We set ours to "Auto" and "Furnace" and that cycles on and off the furnace based on the temperature set. Andrew 1 Andrew 2019 Legacy Elite II 2018 BMW x5 35d
KarenLukens Posted December 2, 2019 Posted December 2, 2019 When we picked ours up, we were told not to use the auto setting because it will cycle between the ac and furnace. So we set it to either furnace or Heat pump depending on the outside temps. If we need to heat the hull to keep the pipes from freezing, then select the furnace. Happy Camping, Reed & Karen Lukens with Riffles our Miniature Poodle 2017 Oliver Legacy Elite II Standard, Hull #200 / 2017 Silverado High Country 1500 Short Bed 4x4 Past TV - 2012 Mercedes-Benz ML350 4Matic BlueTEC Diesel Click on our avatar pic above to find the videos on our Oliver Legacy Elite II
Mac Posted December 4, 2019 Author Posted December 4, 2019 Thanks for sharing your thermostat experiences. The setting that is now working for me is "auto and furnace" but it literally took 15 minutes to cycle to (find) that setting combination. Anything with "heat" or "heat strip" turns on the ac. Solar-DC and propane take care of the rest.
Overland Posted December 4, 2019 Posted December 4, 2019 The heat pump model that Reed and Karen have may well work differently than the heat strip model that most owners choose. With the heat strip model, you must have the fan set to auto if you only want the furnace to run. Otherwise, as you've experienced, the AC fan will also turn on. 1
