This is from the viewpoint of having enough payload for a heavy truck camper, but other than that, everything is completely valid.
https://www.truckcamperadventure.com/diesel-vs-gas-for-truck-camper-rigs-which-is-better/
The reader comments are also interesting.
One thing about a (big) turbo diesel engine that not many consider, is that they are so very relaxing to the passengers on a long road trip. Especially when encountering stiff headwinds and steep grades. No worries Mate.
Interesting JD, although I would quibble with a few of  their viewpoints.
Based upon my experience given the cost of DEF, regular fuel filter changes (10k) , oil and filter changes (7.5k), I would give  the gas burners a much larger advantage in the maintenance and cost to run category. Given the cost dif on fuel - I'd take gas here. ( and I generally change my own)
NVH - in the 3/4 ton area, My 18 GMC is pretty sweet, the gas burner was no better, if  not nearly as good. Note - the fords I drove during my selection process were noticeably rougher on the road - unloaded. I had a 2007 GMC 2500 - it road like a rigid frame chopper - until you put 500 lbs. in the bed, then it was just rough.
Per JD - Now here is THE difference, no question. It is the difference maker for me. (us)
The power and torque difference is so easy to like, the ride is fine, parking in small lots - harder but not that bad. Other than initial purchase price - its an easy choice. Regardless of manufacturer, the diesel is about $10k more - that's a steep step up in overall cost.
RB
