I just stumbled across these and think they would be quite useful for securing stuff temporarily, for example where a small ball-type bungee might normally be used. At $0.50 each they are far too pricy for regular permanent jobs IMHO, unless you just have money to waste, or need it to look especially pretty... in the engine bay of a really nice car for example.
https://www.amazon.com/GRIPLOCKTIES-Releasable-Re-Usable-Industrial-Durable/dp/B07CZLX3MR?th=1
Has anyone used these, and can you comment? Recommended? What do you use them for?
Thanks.
Edited by John E Davies
Those look great to me, for a few applications.
They also sell in smaller quantities.
Sherry
Bought some at EAA Airventure a couple years ago when they first came out. The rubber inserts protect from abrasion, so I can use them on an engine mount - where a standard nylon tie would be problematic.
I haven’t  used them on anything other than on the airplanes, but they would probably be useful in other applications. As you mentioned, they aren’t inexpensive.
2020 Elite II Hull #628 "Pearl" - Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt
TV - 2011 Toyota Tundra Crew Max Platinum 5.7 V8 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
