Our right brake, turn and flasher is out. Left works fine. TV plug checks good and TT connector is good. Hull #428 2019 , do led’s burn out? Does the trim ring on fixture pop off to check fixture or do you have to access through bunk locker? Any help appreciated,thanks.
I am not sure about the bezels. My guess is that they do come out by careful prying with a plastic body tool, not a steel tool! Maybe a call to Service would be a good next step, if you can wait until Monday..... You have a wiring issue if it affects both light units. If just one, then it could be a light failure. LEDs do fail at random, but never all at once. Boards and soldered connections however do fail, possibly rendering the entire unit dead.
Good luck.
I had a left lower running light start blinking  - Oliver replaced it - said it had gone bad..... I thought it was good for many many years...
Good luck.
Thanks for input John, we are safely home but heading out Friday for a few days. I agree with you assessment and will call Jason tomorrow at Oliver. I feel sure it’s a simple fix I just don’t know the steps....yet!
