@LiFeBlueBattery, Oliver has provided cutoff switches to enable isolation of the LifeBlue batteries - both from charge input and battery output.  While camping and attached to either Solar and/or shore power, it seems that the solar and inverter charger(s) keep sending "float" voltage / amps to the batteries and they stay at ~99% most of the time.  Would it be a good practice to use the cutoffs to the charge sources and let the LifeBlues "drain" a bit rather than continuously keeping them topped off while camping?  I can't tell what the BMS is doing when the charge controllers are sending 3.6V (float).  Maybe ok to ignore this on short camping trips but what about full timers and/or long trips?
Thanks in advance!
States Visited Map
I'm glad to read of these cutoff switches, as in another  thread LBB confirmed that  the ideal storage practice is  to get the batteries to  roughly 50% charge and then cut them  off  from  charge and drain, and then monitor and top off periodically as needed to  return to that  roughly  50% state. That discussion  didn't touch  on long term hookup or sun drenched  camping.
Oliver Elite II hull #709
