We have had some odd issues pop up from time to time on our Jensen radio/DVD like loss of sound or settings issues.  We usually just do a menu reset, I recently had to trip the 60 amp breaker to do a reset on the Jensen.  It wouldn’t stay powered on long enough me to get into settings and change the time.  I tried several times and it kept powering itself off.  Finally I resorted to tripping the breaker.  I could have used a fuse or possibly a circuit breaker on the converter, but opted for the main breaker cutoff instead.  It resolved the issue immediately after I reset the breaker.
David
Hull 509 "The Swallow"
Glad you got it fixed.
I too have had "issues" with my audio system from time to time - once every two years or so.  I suspect that the "computer" chip(s) that run the thing gets "confused" and finds itself in a loop.  In any case, a system reset - paperclip into the small hole on the front that is marked "reset" normally does the trick.
