Draining hot water heater during winterization
In reviewing the winterization video, I see Oliver drains the hot water heater at the end of the process.  Our hot water heater is already drained.  I'm hoping this is ok; I don't see why it wouldn't be.
Ray and Susan Huff
1UP-USA Heavy-duty bike rack
Did you use the water heater by-pass valves as per the video to isolate the water heater from the rest of the system?  If you did do this at the beginning of the winterization procedure - the - you are OK.  If not then you most likely used a bunch more antifreeze versus what you would have used otherwise.
Yes . . . . emptied hot water tank, then bypassed hot water heater in plumbing configuration.
Ray and Susan Huff
The most important thing to remember is to turn the water heater off, hours before winterizing. Especially standard water heater. We turned ours off day before when we had the 6 gallon.
