Dave Mazone Posted March 27, 2022 Posted March 27, 2022 Oh how I struggle with technology! I connected to cable at my campground and connected to the cable port on my Ollie. What in the world do I have to do to get the cable channels? (2022 OEII) I have tried everything I know on the remote...nothing helpful in the manuels. Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD)
Moderators Mike and Carol Posted March 27, 2022 Moderators Posted March 27, 2022 For my trailer (2016), there is a box in the attic that toggles between the cable connection and the antenna. There is a little button that switches between the two. If it’s in your attic, push the little button and then try scanning for cable channels again. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Dave Mazone Posted March 27, 2022 Author Posted March 27, 2022 Hi Mike, Yes, I have that switch. It has a connection for satelite and TV1. Neither has a cable attached though. I am rescanning now and... Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD)
Galway Girl Posted March 27, 2022 Posted March 27, 2022 Also in the 2019 and I assume in yours. When you are connected up to a cable port outside the trailer it comes into the "amplifier" in the attic. The AMP is ON when the red lamp is lit. It's only supposed to be on to receive off the air HDTV channels via your antenna. The red light (and amplifier) needs to be OFF to receive CATV , then do a channel scan for the CATV input that is feeding the TV from the CATV pedestal. 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Dave Mazone Posted March 27, 2022 Author Posted March 27, 2022 Thank you, Galway Girl. I have turned off the switch and am rescanning now. Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD)
Galway Girl Posted March 27, 2022 Posted March 27, 2022 That wall mount amplifier channel is hooked up to the HDTV antenna. So when it's on , that input becomes the most powerful input and your TV won't see any CATV channels. So when you turn it off, then the CATV scan should find the CATV channels. One last thing, in my Hull 505 the factory had inadvertently wired the CATV input (outside) to the Satellite input and vice versa. So if you still don't get anything, stick the outdoor cable into the other outside input and rescan. After that I don't know what to tell you. CS 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Dave Mazone Posted March 27, 2022 Author Posted March 27, 2022 That was it Galwaygirl! Thank you! It boiled down to simply rescanning after a cable connection. That's probably what Mike was also implying, but I didn't get it. Thank you guys...We love you. 4 Dave & Terri Mazone 2022 LII Hull #1019 TV: 2001 Chevy Silverado 2500 HD diesel, Crew Cab (4WD)
